Username Post: L72 hydraulic roller cam replacement        (Topic#349631)
chip8541
Platinum Supporting Member
chip8541
Loc: Gardnerville NV
Reg: 03-21-14
02-12-18 09:01 PM - Post#2724210
Tall order here, I have a complete 1965 l78 (air cleaner to exhaust manifold oil pan) and plan on boring it out to 427 specs. In effect making roughly l72 specs. (Yes it is a 962 block and will be sonic tested.) Got a smoking deal on what is probably the only rolling l78 IE code chassis/drivetrain radiator and shroud that someone stored for years.
It is going in a 1965 Impala, M21, 3.73 posi rear.
I am am at a crossroads, I want a hydraulic roller cam in it. I want to run power disc brakes.
Option 1 - 11:1 factory type pistons (good for the rectangle ports, more rpm with more duration,) Is this possible with power brakes?
Option 2 - 10:1 pistons (less duration, less than optimal for the rectangle ports, better for power brakes)
Option 3 - Sell the 962 block, Buy a Dart big M block, build a 509 with the 208 heads at 9.6:1 and slap the zz502 cam in it. Dress with l78 parts, enjoy the cubes, the power brakes and live with the choked down l78 exhaust manifolds.
Option 4 - Solid lifter factory cam and enjoy the engine for what it is.
What cams would you all recommend for option 1 and 2?
How many would go option 3 and 4?
I am concerned about gas quality and detonation.
Thanks in advance for your input.
Edited by chip8541 on 02-12-18 09:05 PM. Reason for edit: No reason given.
Execution time: 0.319 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:27 PM
