Username Post: Trans fluid!        (Topic#349605)
100 CHEVY
100 CHEVY
Loc: Helena,Missippi,U.S.A.
Reg: 12-09-04
02-11-18 11:11 AM - Post#2724049
Just exactly why are there so many different types of this stuff?
Type F,Mercon V,Dexron 1,2,3,4!
Then,each engine has to have a specific type for year it's made?
Or,can I just put my tractor fluid in them?
Somebody try to explain this to me please!
Thanks,Mike.
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
02-11-18 11:19 AM - Post#2724052
    In response to 100 CHEVY
Your engine doesn't need any transmission fluid.
99 K3500 RCLB
02-11-18 11:55 AM - Post#2724057
    In response to 454cid
LOL...literalist
Mike, what year/model/transmission?
The Dexron stuff all the older numbers are just that, older. They get phased out as new specifications evolve, and the new stuff replaces the old. Dexron VI is current and you would use it in anything that specifies a previous version of Dexron fluid. The newer transmissions require it as they have been designed in a way that has special fluid needs, just the same as newer engines have different oil specifications.
Info straight from the source:
http://www.acdelco.com/auto-parts/vehicle-ma intena...
IgnitionMan
Reg: 04-15-05
02-11-18 12:03 PM - Post#2724060
Not all transmission manufacturers use the same component parts in clutches, servo's, bands, other specific parts, and with them, comes individual fluid "builds" to work with all the different parts. So, what works in a GM automatic, won't usually work with all the different components in a Ford automatic.
100 CHEVY
100 CHEVY
Reg: 12-09-04
02-11-18 02:07 PM - Post#2724079
    In response to someotherguy
Well,I have lot of them!
350's,400's,700-r4's,4L60 E,4L80E and,a 200r.
Plus the wife's Cavalier and mom's Mercury.
When I see a new type come out,makes me wonder if I'm using the right type or do I need to change?
I'd just as soon continue using what I've been using instead of having more types to deal with.
I've a 99 GMC that's been getting Dexron 3.But,I read that's not correct for transmissions newer than 95.
That's the reason for the post.
Mike.
Edited by 100 CHEVY on 02-11-18 02:11 PM. Reason for edit: No reason given.
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
02-11-18 03:13 PM - Post#2724087
  • someotherguy Said:
LOL...literalist
I have no idea what you're talking about :-)
Is Dexron III not still widely available? I wouldn't jump to the synthetic stuff unless I had to. Edit: I see GM only supports VI, but other manufactures still market unofficial fluids that meet the standard.
99 K3500 RCLB
Edited by 454cid on 02-11-18 03:19 PM. Reason for edit: No reason given.
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
02-11-18 03:18 PM - Post#2724089
Mike.
Dextron III is probably what it came with. I don't think Dextron VI was a thing until the 2000's.....Wikipedia says it wasn't factory fill until 2006.
99 K3500 RCLB
02-11-18 06:39 PM - Post#2724115
Dexron is backwards compatible all the way back to "Type A" transmission fluid from the 50s.
In other words, if your vehicle came with Dexron of any kind, or Type A, the latest Dexron is just fine for it.
Older Fords use "Type F" which is different stuff, some used it to get a GM transmission to shift firmer.
Later Fords use "Mercon", and there are fluids that meet both Dexron and Mercon specs.
Now foreign stuff is another matter.
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
02-12-18 12:11 AM - Post#2724133
    In response to Rick_L
I've considered that, but have never had the guts to do it.
99 K3500 RCLB
elcamino
elcamino
Reg: 03-30-00
02-13-18 04:42 AM - Post#2724227
Automatic Transmission Fluid
2016 Polaris RZR 900 EPS
69_BOWTIE
Loc: WYOMING,USA
Reg: 02-27-02
02-13-18 06:21 AM - Post#2724231
    In response to elcamino
Some of us also use it in our Harley primary clutch's.
2001 Silverado 4X4
2005 FXDWGI
69 CHEVY Short Step
63 IMPALA 2/DR HRDTOP 327
02-13-18 07:38 AM - Post#2724234
    In response to 69_BOWTIE
Good lord I tried it but a Shovelhead can't keep that slippery fluid inside the case. Wanna talk about a mess!
I switched to open belt drive after all that...
Execution time: 0.473 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:28 PM
