Username Post: Intermittent Heated Seat issue        (Topic#349591)
DarkLordofIT
Loc: Idaho
Reg: 02-10-18
02-10-18 12:54 PM - Post#2723971
There are plenty of threads on heated seat issues but I can't seem to find one quite like this. On both the drivers and passengers side in front, the heated seats one day began behaving erratically. The back always works without issue but will not switch or heat the bottom. However, press the button a few (or many) times and it will turn on the bottom element and works just fine. Today, for example, I started the truck and the bottom heated seat turned on, allowed me to change the level without issue, the passenger side only the back would work. Other days if I hit the bottom seat button 10-20 times in a row it will suddenly start working no issues. It does not appear to be an element issue as the lights do not come on and then turn off and when t works it works perfectly. Could it be a bad control module?
LMC Trucks
Execution time: 0.253 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:36 PM
