Username Post: 66 4 Speed Hump Placement        (Topic#349580)
65acadian
65acadian
Loc: Manitoba, Canada
Reg: 08-15-04
02-09-18 03:59 PM - Post#2723906
I am doing a 4 speed conversion on a 66. I'm not new to doing this, I did the identical conversion a few years ago, so I'm aware of all the parts needed etc. One thing I don't have though is anything that tells me about locating the hump correctly. Last time I did it, the floor in the car already had a hole in it for the auto console shifter. This time it's a column shift car so I start from scratch and I'm doing a very original 40,000 mile car. I want to get it right and do a nice job. Does anyone have measurements and pictures of correctly placing the floor hump?
I checked in the archives here and the resource section but I can't find anything about that exact question.
Thanks.
65acadian
65acadian
Reg: 08-15-04
02-09-18 04:07 PM - Post#2723908
    In response to 65acadian
I found some help in an old post of mine from 6 years ago when I asked a similar question!
But if anyone has pictures of a bare 4 speed floor and some dimensions it would still be a big help.
Texasray
Texasray
Reg: 11-01-16
02-10-18 03:33 AM - Post#2723928
I found this while searching the net for custom consoles.
Sam
65acadian
65acadian
Reg: 08-15-04
02-10-18 07:41 PM - Post#2724002
    In response to Texasray
Thank you, I did find that thread eventually. I worked on it today and that makes total sense. The specs given---
"Opening is 4-1/2" wide and 6" front to rear. The rear of the opening is 2-1/2" foward of the second sill plate screws. The top edge of the opening is 1" off center to the drivers side.
I took these measurements from my original 4-speed 66 Impala."
So that is what I did today. I didn't cut a hole yet though. I have a borrowed original hump that I used to mark it. Now I am waiting for my repro hump to arrive (and I hear it won't fit as well, but at least I know where it has to be located now and I can make it fit.)
Edited by 65acadian on 02-10-18 07:42 PM. Reason for edit: No reason given.
aghaga
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
02-11-18 07:38 AM - Post#2724021
Leave plenty of metal for overlap. Every factory floor cut under the hump that I have seen looked like it was crudely cut with a torch of some sort.
astrojet427
astrojet427
Loc: Vancouver, B.C.
Reg: 11-22-05
02-11-18 10:07 AM - Post#2724047
    In response to aghaga
Just curious. Two things, can someone advise: is the style of hump (shape/design) the same for both console and non-console applications, and is the floor location the same for console and non-console applications?
1967 Impala SS. 327-Turbo 400; 12 bolt-3.55 gears. A few photos of my '67.
1972 Corvette Convertible Mille Miglia Red 4 speed.
1963 Cadillac Eldo-Triple Black.
aghaga
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
02-11-18 11:33 AM - Post#2724065
    In response to astrojet427
same
65acadian
65acadian
Reg: 08-15-04
02-11-18 03:40 PM - Post#2724101
Yes, they didn't do a nice job cutting them. Chevelle and Nova are the same way.
65acadian
65acadian
Reg: 08-15-04
02-11-18 03:47 PM - Post#2724103
https://photos.google.com/photo/AF1QipMfgg1jaSm eai...
65acadian
65acadian
Reg: 08-15-04
02-11-18 03:48 PM - Post#2724104
https://photos.google.com/photo/AF1QipNv1pS-vfQ vD-...
Execution time: 0.272 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:12 PM
