Username Post: What is the best reason for removing lead?        (Topic#349576)
blue_63
blue_63
Loc: N Dakota
Reg: 11-06-01
02-09-18 01:15 PM - Post#2723892
I am working on a '38 coupe, that obviously has lead in all the seams. The lead appears to be in great shape, no cracking or any other issues. If I sand it lightly, just to get a look at what is below the skin, it looks like someone just leaded it. So I am wondering why remove this lead? As opposed to leaving it in?
Greg
100 CHEVY
100 CHEVY
Loc: Helena,Missippi,U.S.A.
Reg: 12-09-04
02-09-18 03:36 PM - Post#2723902
    In response to blue_63
I removed all the lead on my 57.
The reason is that I didn't know what was under it after all the years.
I found rust,not bad,but it was there.
I welded all the seams solid and epoxy primed them.
These are all spot welded seams and moisture can and did get in from the back side.
Probably not the best reason,but it's what I think was best for my car.
Mike.
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
02-11-18 09:31 AM - Post#2724041
Mike makes a good point in the above post. Another reason is that over time, lead can react to finishes that are applied over it evidenced in the photo below of a 1938 Buick. I'm not saying that lead will absolutely react with modern finishes but I would say that the possibility does exist. When I re-shot my '51 Business Coupe, I took them all out and refilled with modern plastic fillers.
1951 Fleetline
Execution time: 0.393 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:57 PM
