Username Post: Cam Changes        (Topic#349568)
rawaag
rawaag
Loc: Williamsburg Virginia
Reg: 06-12-09
02-08-18 05:23 PM - Post#2723808
Ok guys I'm back with a few more questions, since I know this is the best place to good answers. My 52 Chevy 235 engine is starting to get tired and noisy. I have a spare 235 engine we are planning on rebuilding. Numbers on the block tell me its 1958- 1962, so my upgrades to the old engine will transfer over. We are wanting to upgrade the cam to something a little more peppy. But I must admit I know very little about cams.I'm not planning on racing or pulling anything so I don't want anything to strong. I've spent all day trying to find one to fit my engine and found a few. They show as 240/248 or 260/272 duration. What would I be getting with the 240/248 duration,almost stock? Thinking I should have something a bit higher? I will change the lifters but don't won't to change the springs. I understand the engine has hydraulic valves and want to stay with the hydraulic. Could someone explain what I'm looking at and where I'm most likely find what I need?
Thanks guys!
Ralph
2blu52
2blu52
Reg: 03-12-02
02-08-18 06:45 PM - Post#2723817
    In response to rawaag
What I would do and is what I suggested when I worked as a counter man was to settle on a producer for the cam I wanted, then call the Tech folks and discuss with them what I wanted from the cam and what other changes were going to be made to the engine. Never had any one get upset with me for that except a fellow who built a 261, ordered a Corvette cam for it and then found out that that was the stock OEM cam for the engine.
THOMAS JEFFERSON
50sChevys
50sChevys
Loc: Central Texas
Reg: 03-23-02
02-08-18 06:55 PM - Post#2723819
    In response to 2blu52
I bet he was not happy! Lol
50s Chevys
02-08-18 10:51 PM - Post#2723837
    In response to 50sChevys
At least he had a spare!
2blu52
2blu52
Reg: 03-12-02
02-09-18 06:26 AM - Post#2723855
THE REST OF THE STORY:He raced the engine for several years, sold it to a farmer who installed it in a home made hay rake who used it for over 10 years and then parked the outfit. About 5 years ago he called the original owner asked if he wanted the engine back so the 261 now sits in his garage with the vet cam in it.
THOMAS JEFFERSON
02-09-18 06:52 AM - Post#2723858
Good. I love happy endings.
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
02-09-18 07:20 AM - Post#2723863
Installing a cam that will give the engine"more pep" ??????
Installing a more "radical" cam will give the engine LESS power at lower engine speeds, like under 2500-3000 RPM and more power at higher engine speeds. If you do not wind out the engine through the gears and most of you driving in under 60 MPH you want a "conseritive" cam.
In 1954 Chevrolet used a higher lift cam in the Power Glide enginnes and all engines in 1956. They went back to a lower lift cam in 1959 for better fuel mileage and more engine power at the lower engine speeds - and it worked fine. Advertised horse power went from 145 at 4200 RPM to 135 at 4000 RPM but for general driving the car felt peppier at normal engine speeds ispite of the fact that the 1959 gained weight.
The highest lift solid lifter cam Chevrolet used was the one used in the 261 truck engine, 1953-1954 6 Cyl. Corvettes and 1956-1958 235 trucks.
The high lift Hyd. version used in 1954-1958 Power Glides and 1956-1958 sticks.
The "Vet" cam the engine has is a the same cam used in a 235 truck 1956-1958 and a 261 truck.
Edited by Gene_Schneider on 02-09-18 07:22 AM. Reason for edit: No reason given.
rawaag
rawaag
Reg: 06-12-09
02-09-18 07:49 AM - Post#2723866
    In response to Gene_Schneider
Gene, thanks for the quick response. Your correct I seldom drive above 60 and on a rare occasion might go on the interstate for a short distance. I don't won't anything to radical, just a little more pep. I've looked at Langdon's site and he offers one mechanical cam with a 260/272 duration?Like I said I know very little about cams and the different grinds. Should I be looking for something less than this? I've also looked at Summit and they offer a couple of cam kits but don't know what I should be looking for. Any help would be greatly appreciated.
Ralph
rawaag
rawaag
Reg: 06-12-09
02-09-18 07:58 AM - Post#2723868
2blu thanks for the tip. I've had a little chat with the people at Summit but only gave me a list of the cams they had in stock. I usually talk with Tom Langdon but he's on vacation until March. I tried Speedway but didn't get a response. I'll keep looking and asking until I find the right cam.
Sr Driver
Ralph
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
02-09-18 09:20 AM - Post#2723876
I can't answer the duration question but for normal driving the stock cam will give the best performance and smothest idle.
Just a fresh engine with good compression an increse in power over a worn out engine.
The later 235 engine with its aluminum pistons and higher compression ratio will give better performance.
If you have Power Glide you want an engine with good low speed torque and not high Speed horse power. I would also suggest in keeping the hydraulic lifters. A higher lift cam will require stronger valve springs.
Edited by Gene_Schneider on 02-09-18 09:26 AM. Reason for edit: No reason given.
02-09-18 10:16 AM - Post#2723879
That 260 figure is an advertised figure only, to accurately compare cams you need the duration figures at .050 lift. Plus lobe seperation.
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
02-09-18 10:19 AM - Post#2723880
PBM Erson has cam blanks in stock , they have a 260F grind with 410 lift 260 duration that is a milder cam.I have ran the 280F 440 lift and 290F 460 lift, they are a little aggressive for normal driving but fun with the right transmission and rear axle to drive.
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
02-09-18 12:27 PM - Post#2723891
With the Power Glide and 3.55 gears the engine never gets up to 3000 RPM unless you wind it out in low range over 35 MPH.
For 3000 RPM in drive you have to get over 70 MPH.
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
02-10-18 01:23 AM - Post#2723924
Hi Rawag, I'm with Gene on this. The cars generally cam with the right cam given their use, piston material, follower type, compression and gas quality.
Unless you have changed the cars physical parameters a lot why would you need to change the cam?
Modern fuels are higher octane, so there is some latitude to raise the compression if you use modern construction pistons. But this is an old style combustion chamber and although folks do big cuts and reworks on them for just road use the 261/vette cam, shaved head, twin carbs and dual exhaust with electronic ignition is all you need.
If you need more than 150Hp and over 3000rpm all the time then change engines.
Cheers Kiwi
rawaag
rawaag
Reg: 06-12-09
02-10-18 07:45 AM - Post#2723944
    In response to cbmkr56
Thanks for the name of the cam manufacture, I'll look them up and see what they offer. I'm getting a little more educated on cams, since I took some time read information on the Summit site. Hopefully the information I've gathered will help in a selection.
Ralph
rawaag
rawaag
Reg: 06-12-09
02-10-18 07:56 AM - Post#2723945
    In response to Bel Air kiwi
Hi Bel Air, I'm running 3.56 rear and a Saginaw 4 speed but feel like there should be a little more zip when in 3rd gear. I don't know what RPM's I'm hitting but the engine is loud. I'll have to buy a new tack since the old one died 6 years ago. But putting a fresh engine in front should help a lot.Thanks for the response, I can always count on the guys on CT.
Ralph
rawaag
rawaag
Reg: 06-12-09
02-13-18 01:05 PM - Post#2724281
Ok guys, I think I have enough information from all the input I gathered here and Summit to order a cam set. I'm plan on ordering from Summit cam and lifters CL61-113-4. Advertised duration 240/245 lift.455, operating range 500-4500 rpm. How does that sound to you guys?
Ralph
BAJohnny
Loc: Kentucky
Reg: 04-04-13
02-13-18 02:42 PM - Post#2724286
According to the Summit Web Site that cam is for a
Chevy, 194, 230, 250. Not A 235!
1953 BelAir 2dr Sedan
1953 BelAir 2dr Hardtop
rawaag
rawaag
Reg: 06-12-09
02-14-18 07:20 AM - Post#2724353
    In response to BAJohnny
Yes, I've made that mistake in the past thinking that it covered 194 thru 230 thru 250. So I didn't order it, even if that was the number given by one of the persons at Tech Help. So the hunt goes on, I have a couple of other places to try. Thanks for the comment.
Ralph
rawaag
rawaag
Reg: 06-12-09
02-21-18 10:27 AM - Post#2725108
I made a call to Patrick's last week and he helped me enough to make a decision on what cam I should use for what I wanted. We talked it over and I ordered a cam from him. So thanks to all you guys out there that helped educated me a enough on cams,to buy one. Thanks to CT for all the help I've obtained over the years in building and keeping my car running.
Ralph
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
02-21-18 02:50 PM - Post#2725127
Keep on top of him and make sure your order gets shipped.
55 Shaker
Loc: north central IL.
Reg: 03-13-06
02-22-18 01:37 PM - Post#2725242
Patrick's doesn't have a very good track record.
02-22-18 02:27 PM - Post#2725252
    In response to 55 Shaker
That's not very encouraging to hear. Unfortunately, Patrick's carries a few items which don't seem to be available from any of the other usual sources. One example would be the Saginaw torque tube conversion.
rawaag
rawaag
Reg: 06-12-09
02-24-18 10:00 AM - Post#2725435
Ray, it's the first time I've ordered from him and he did say it would be a few weeks. I was thinking the shop who does his cam's could take a couple of weeks. Fortunately we're not waiting on the cam to start the rebuild, waiting on my wallet for it to refill. I also, this week ordered a new short water pump. Let's see how long it takes for these items to arrive. I'm hoping they aren't coming from China.
Ralph
Execution time: 0.349 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:49 AM
