Username Post: new motor sits at an angle, swapped out a 6cyl for 350 SMBLK        (Topic#349566)
Dave Boro
Reg: 03-05-17
02-08-18 03:29 PM - Post#2723784
1961 Biscayne.
Replaced original 6 cyl with a crate 350. Factory motor mounts reused attached on the frame, new ones on the motor, motor sits low in the rear high in the front. Anyone run into similar situation when swapping out a 6cyl?
turbo38s10
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
02-08-18 03:33 PM - Post#2723785
    In response to Dave Boro
You need v8 frames mounts they are different than v6 mounts.
Dave Boro
Reg: 03-05-17
02-08-18 03:35 PM - Post#2723786
    In response to turbo38s10
Any idea where I can order these?
Dave Boro
Reg: 03-05-17
02-08-18 03:45 PM - Post#2723788
These???
https://www.lategreatchevy.com/full-size-chevy-eng...
turbo38s10
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
02-08-18 03:46 PM - Post#2723789
that's them. You may find someone here who has a used set cheaper.
pvs409 member comes to mind
Edited by turbo38s10 on 02-08-18 03:47 PM. Reason for edit: No reason given.
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
02-08-18 05:52 PM - Post#2723804
Correct I do...-private message sent.
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
62 Imp CV SS 327/300HP 700R4
62 ImpHT SS 409/482 stroker 4 spd
62 Imp SS 409 - 5 spd Convertible under frameoff
Website http://paulstensland.com/
[image]http://chevytalk.org/sm/26453.jpg[/ima
IgnitionMan
Reg: 04-15-05
02-09-18 07:09 AM - Post#2723854
Also understand that our engines do sit in place at a for to aft angle, as does the drive shaft yoke on the differential. They sit a couple of degrees higher at their front, than their rear.
On stock suspension vehicles, the carburetor mounting pad should sit level, engine on the angle, when the vehicle sits on level ground.
Execution time: 0.698 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:36 PM
