Username Post: Rear Window Molding Install        (Topic#349564)
smokey1963
Loc: Altoona, PA, USA
Reg: 06-16-02
02-08-18 01:48 PM - Post#2723768
Looking for some advice. I am installing the molding on the rear window of my 63 impala. The top two pieces went right on, but the center piece on the bottom does not want to catch the clips. Am I missing something or do I have the wrong clips?
1963 Chevy Impala SS 409
Retirement Isn't All That People Say It Is. IT IS EVEN MORE!!!!!!!!
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
02-08-18 06:29 PM - Post#2723810
    In response to smokey1963
Do you have the 4 clips installed that are in the middle picture of back and side stainless molding set of reveal mldg and mounting clips for 62 to 64 Hardtops?
They slide into the lower stainless piece "only one way" and they matchup with the reveal molding clips.
https://www.lategreatchevy.com/full-size-chevy-rea...
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
62 Imp CV SS 327/300HP 700R4
62 ImpHT SS 409/482 stroker 4 spd
62 Imp SS 409 - 5 spd Convertible under frameoff
Website http://paulstensland.com/
[image]http://chevytalk.org/sm/26453.jpg[/ima
smokey1963
Reg: 06-16-02
02-09-18 04:52 AM - Post#2723846
    In response to pvs409
I have the clips installed in the two wrap around pieces, just can't get the center piece they connect to, to snap over the clips. Hoping it is not a bad set of clips or the wrong ones.
smokey1963
Reg: 06-16-02
02-09-18 07:29 AM - Post#2723856
The four clips in the middle of the picture are they for the bottom of the window frame? If so then I installed the wrong clips on the bottom. The ones I installed were the same as the top. The four clips do they attach with screws as the others do? Sounds like I may have to pull the window out and change the clips.
Edited by smokey1963 on 02-09-18 07:31 AM. Reason for edit: No reason given.
69_BOWTIE
Loc: WYOMING,USA
Reg: 02-27-02
02-09-18 08:13 AM - Post#2723861
Yes the bottoms are held in place by screws they are different than the top clips.
2001 Silverado 4X4
2005 FXDWGI
69 CHEVY Short Step
63 IMPALA 2/DR HRDTOP 327
Edited by 69_BOWTIE on 02-09-18 08:14 AM. Reason for edit: No reason given.
pvs409
pvs409
Reg: 01-10-05
02-09-18 09:53 AM - Post#2723873
    In response to 69_BOWTIE
There are no screws that hold the stainless piece that sits against the rear window rubber on 62 to 64 Hardtops
The only screws(actually hex nuts on mounting studs) for the bottom of the 1962 2 door Hardtop rear glass are on a extra pot metal chrome (with black painted inserts) that "fits over the stainless trim" that sits against the lower windshield rubber.
I took some pictures of the stainless trim and the slide in clips for the lower rear stainless -I will post them later today
Paul
pvs409
pvs409
Reg: 01-10-05
02-09-18 10:43 AM - Post#2723877
here are the pictures. The first picture shows the 62 Chevy Hardtop pot metal piece(bottom of the picture) -only used on 62 Hardtops... + the lower stainless and one clip(there are 3 to 4 slide in clips are used on the stainless)
The single clip and lower 62 to 64 2 door Hardtop stainless is in the next two pictures.
Paul
Attachment: IMG_0013-004.JPG (92.45 KB) 8 View(s)
stainless for 62 to 64 2 dr Hardtops top in the picture -pot metal 62 Hardtop only piece in the bottom of the picture
Attachment: IMG_0015-004.JPG (92.55 KB) 4 View(s)
one slide in clip (there are 4 to be used) partially installed in lower stainless
Attachment: IMG_0017-004.JPG (95.46 KB) 4 View(s)
clip installed in the lower stainless that fits against the windshield rubber - with the bottom of the clip in this picture is toward the body of the car
smokey1963
Reg: 06-16-02
02-11-18 03:26 PM - Post#2724091
I appreciate all the time for the replies. I sat and thought until I had a headache. I had thought about having the wrong clips and having to pull the rear window. Out of desperation I looked at all my old clips which with luck I had bagged and tagged. The note said rear window lower molding two piece clip. Amazing how much a person forgets after disassembly 15 years ago. Molding now installed.
Execution time: 0.518 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:09 PM
