Username Post: Instrument Needles        (Topic#349561)
SandDabMcSkeg
Loc: Coos Bay, Oregon
Reg: 01-04-18
02-07-18 07:41 PM - Post#2723701
What color were the instrument needles and clock hands on a 51? What paint do you use to restore them, and where did you get the paint? Anyone have pictures of gages with custom colors? On my 57, they were a glow orange, really shows up at night, my 46 is original with red. I thought I heard somewhere they were a pale green? Is this right?
Edited by SandDabMcSkeg on 02-07-18 07:41 PM. Reason for edit: No reason given.
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
02-07-18 08:07 PM - Post#2723704
    In response to SandDabMcSkeg
Directly from the 1951 Chevrolet Engineering Features Booklet, "Pointers, graduations, and figures are a non-glaring, off-white color which has a slight green tint".
1951 Fleetline
SandDabMcSkeg
Reg: 01-04-18
02-08-18 12:40 AM - Post#2723720
    In response to RAM_51
Thanks, that is what I had heard somewhere, now, next question, where do you get that at? Source for paint?
RAM_51
RAM_51
Reg: 12-28-02
02-08-18 07:39 AM - Post#2723735
Personally, I'd go down to my local hobby shop and get some of the paint in little bottles and mix some myself. That is if you can find a "brick and mortar" hobby shop anymore..or maybe a craft outlet that sells models and supplies.
1951 Fleetline
mahlmann
mahlmann
Loc: Las Cruces, NM
Reg: 01-20-11
02-08-18 08:49 AM - Post#2723740
I've used Testors enamel for badges, ornaments, grills and hubcaps with good results. It holds up well too.
Good luck with yours!
Mike Ahlmann
Las Cruces, NM
'50 Tin Woodies (two) Ramon and Willard
'58 Impala Sport Coupe
'69 El Camino SS-396
'07 Ford F150 to haul parts for above
'16 Ford Explorer 3.5 EcoBoost - Red Rocket
SandDabMcSkeg
Reg: 01-04-18
02-08-18 10:02 AM - Post#2723750
    In response to mahlmann
I used Testors as a kid building models, but there is nowhere inside of 2 hours from here that has it anymore. I guess kids don't build them anymore. It was 15 cents a bottle when I was a kid, the last I bought was just under $2. Maybe that's why they don't build models anymore, lol. So, there is no pe-mixed color anyone uses. I think I just may go the dayglow orangeish red I already have.
eplantage
Loc: Southern MN
Reg: 03-15-04
02-08-18 02:45 PM - Post#2723780
The only place I've found locally that sells models and paint is Hobby Lobby. There are a few online model stores. www.shorelinehobby.com
Age: 63 at the moment
1950 Chevrolet Sedan Delivery
2002 Heritage Springer FLSTSI
1930 Model A Standard Coupe
SandDabMcSkeg
Reg: 01-04-18
02-08-18 06:46 PM - Post#2723812
    In response to eplantage
So, in summary, there is no source for the correct pale green color. Unless you want to mix it yourself.
Mike JW
Mike JW
Loc: Arroyo Grande, CA
Reg: 01-19-06
02-08-18 07:10 PM - Post#2723816
Pismo Steve has the Paint
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
02-11-18 09:14 PM - Post#2724125
    In response to Mike JW
Hi Guys, the correct source for the pale green luminous paint they used on speedometers and gauges is a nuclear facility.
From memory it was a uranium variant and you can't buy the paint anymore.
If it glows in the dark and it's green it's either a martian or radioactive.
Cheers Kiwi
RAM_51
RAM_51
Reg: 12-28-02
02-12-18 07:42 AM - Post#2724143
    In response to Bel Air kiwi
The engineering manual does not specify that this was luminus paint. I've had a 1951-52 clock sitting under direct light from my desk lamp and when I turn all the lights out in the room, it does not glow. I believe if it were, the half life would have not been exceeded in 67 years and It would at least give off a faint glow....none. I think I remember reading that Studebaker was doing that along with wrist watch manufactures...Chevrolet in 1951-52 with their automobile dash gauges?..no.
1951 Fleetline
SandDabMcSkeg
Reg: 01-04-18
02-12-18 10:31 AM - Post#2724150
Yeah, it doesn't glow in the dark, it's just pale green paint. I wondered if anyone has a source for that color that's easy and looks good. It was not radioactive or anything.
SandDabMcSkeg
Reg: 01-04-18
02-12-18 10:31 AM - Post#2724151
dsacton
dsacton
Loc: Boulder, CO
Reg: 11-01-11
02-12-18 06:57 PM - Post#2724193
Radioluminescent paints in the 50's most-likely used Radium-226. The radium isotope has a long half-life (more than 1000 years), but it degrades the phosphorous in the dials. So it might not glow today, even though it would still be just as radioactive. I'm going to see if I can get my hands on a Geiger counter to check my dash. I can say with certainty that the numbers did not glow as early as 1979, when I got the car.
Actually, I bet 2blu remembers if these ever glowed.
Scott Acton
1954 Chevy Bel Air 2-door
http://www.my54chevy.com
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
02-12-18 07:39 PM - Post#2724196
    In response to dsacton
Hi Guys, I wasn't being serious about our cars having radioactive needles, just saying that's what the luminous ones used to be.
If your car is radioactive then chuck out your mobile phone.
The problem is if you are old enough to remember them new then you probably won't.
Cheers Kiwi
Edited by Bel Air kiwi on 02-12-18 07:40 PM. Reason for edit: No reason given.
SandDabMcSkeg
Reg: 01-04-18
02-12-18 07:54 PM - Post#2724202
After all this banter about radioactive stuff, as to my original question, it sounds as though there is nobody who knows an easy source for the pale green color, radioactive or not. It seems mix your own or use the color of your choice is the answer. So I will either go original and mix some up, or go with the 57 Chevy red/orange day glow I already have. There is a company who sells a reflective needle paint, and they have white, and they have a medium green, maybe mixing those together might be cool.
RAM_51
RAM_51
Reg: 12-28-02
02-12-18 08:07 PM - Post#2724204
Four 51-52 Chevolet clocks in my possesion...not a single one glows or even gives off the slightest hint of a glimmer. If mixing this paint, start with the lightest color...add a small drop into the amount of white you think you will need to do the job....keep adding the darker color to the light in small amounts until you arrive at the tint that looks right. Keep in mind that the paint will usually dry just a touch darker than the mix. Let us know what you end up doing and let us all see what it looks like.
1951 Fleetline
SandDabMcSkeg
Reg: 01-04-18
02-12-18 08:43 PM - Post#2724205
Will do. I need to learn how to post pix, I'd like to just post a pic of the car, it is going to be pretty nice before too long.
02-12-18 10:44 PM - Post#2724217
Posting photos.
ragtp66
ragtp66
Reg: 12-09-07
02-15-18 07:08 PM - Post#2724526
Give these guys a call and see if they can help you. https://www.bobsspeedometer.com/1/120/index.asp
Toys:
1987 Sea Ray Pachanga 22
Execution time: 0.363 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:14 AM
