Username Post: Mystery cam specs??        (Topic#349546)
ShortyLaVen
Loc: Minneapolis, MN, and Phoe...
Reg: 01-23-18
02-06-18 09:29 PM - Post#2723602
Hello! I found this old paper for the cam that's currently in my 327. Based on some of the info here, I am guessing it's an old General Kinetics grind, but I'm unsure. I know it was bought through Arcata Automotive (the local parts store/speed shop my mom worked at) in the early 2000s. They carried stuff from Motor Warehouse, and I believe stocked a lot of Speed Pro/Sealed Power parts... Looking in my Speed Pro book I can find a cam with the same duration @ 0.050, same lift, but the advertised duration is what makes me think General Kinetics. I have seen a post on another site about a GK cam with the same specs posted, but there was no more info on that thread regarding this cam. Does anyone out there recognize this? Maybe the layout of the card itself could be a clue? Thanks in advance for any help!!!
scrambldcj8
Loc: MA
Reg: 04-06-03
02-07-18 05:51 AM - Post#2723616
    In response to ShortyLaVen
Might get more info (ID'ing numbers) off the actual cam....unfortunately it's still installed.
Maybe someone has those cam grind numbers/manufacturer off the top of their head? Seem pretty generic to me though
02-07-18 07:46 AM - Post#2723629
Don't go by advertised duration as every cam manufacturer has their own method of determining that. Match by .050 specs and lift. What are you trying to determine, the manufacturing source?
TAT_2
"17th Year" Silver Supporting Member, and Official CT Grim Reaper
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
02-07-18 02:32 PM - Post#2723672
I REMEMBER THE CATALOG,I RAN A GK SOLID LIFTER BUMP STICK WHEN I REDID THE TOP END IN MY OLD 68 L71.I LOOKED THRU THE CATALOG TO SEE HOW MUCH EXTRA LIFT I COULD GET OVER STOCK WITHOUT VALVE TO PISTON CLEARANCE,THAT WAS NOTED IN THE CATALOG,BUT THAT WAS DECADES AGO.
09 PONTIAC- VIBE
08 PONTIAC- G6
96 FURD F-150 SUPER CAB XLT 4X4
NEXT ?
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
02-07-18 03:16 PM - Post#2723676
    In response to TAT_2
chevy part number 12353918
Hyd. - 214/224 - .442/.465 - 112 - GM Crane marine & off road
Edited by grumpyvette on 02-07-18 03:27 PM. Reason for edit: No reason given.
02-07-18 04:54 PM - Post#2723686
    In response to grumpyvette
Wow, how did you find that!?
TAT_2
TAT_2
Reg: 10-29-00
02-07-18 05:06 PM - Post#2723688
MAY THE GRUMP LIVE LONG & PROSPER !!!
SINCE I JUST PICKED UP THIS GEN2 LT1 I HAVE A LOT OF HIS INFO BOOKMARKED
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
ShortyLaVen
Reg: 01-23-18
02-08-18 08:16 PM - Post#2723831
Thanks for the replies!!! I was mostly curious about the manufacturer. I'm also curious if anyone here runs a similar grind, and how it has performed. Right now this engine has an open plenum manifold on it (80s Holley Street Dominator) and has zip for low end... I just picked up an older Weiand Stealth to throw on it, I think that will be a much better match!
TAT_2
TAT_2
Reg: 10-29-00
02-09-18 04:10 PM - Post#2723909
I RAN A TRANTULA MANIFOLD,WIDE OPEN,THE CARB SAT SIDEWAYS TO HAVE EQUAL DISTRIBUTION TO EACH CYL WAS THE THEORY,SUCKED ON THE STREET,BUT I DID MOST OF MY DRIVEN ON I-95, ALWAYS HAD A DAILY DRIVER FURD THO.
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
1983G20Van
Loc: Bedford, Texas, USA
Reg: 11-13-02
02-09-18 06:22 PM - Post#2723912
I ran a Weiand 7525 under a Q-Jet on a 305 with a 216/216 @ .050 cam and it had plenty of low-emd torque.
Execution time: 0.258 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:24 PM
