Username Post: Anti-lock "brakes" are trying to kill me.        (Topic#349516)
427_4speed
427_4speed
Reg: 01-31-03
02-05-18 01:00 PM - Post#2723445
My anti-lock "brakes" are out to get me. On my 2001 Silverado. When i drive into my driveway on dry ground they will growl and I can't push the pedal! have almost hit the garage! backed out of my driveway and they growled again can't push the pedal and I shot out
into the street fortunately no one was coming. I removed the 60amp fuse under the hood, now my brakes work just fine but I have the Anti-lock light and the brake light on all the time Grrrr I had similar issues with my Impala! I hate Anti-locks. is there a way to disable them without all the warning lights? Or an fix?
If it ain't broke keep fixing it till it is! That's the Goverment way!
Edited by 427_4speed on 02-05-18 01:02 PM. Reason for edit: No reason given.
LMC Trucks
02-05-18 01:18 PM - Post#2723448
    In response to 427_4speed
In the salt states this was common and GM had a tsb referring to it. The front wheel speed sensors failed and at low speeds the abs actuated after getting false readings from one of the sensors. Fixed a bunch in my shop. Rust on the sensor mounting surface caused this. Tape over lite? Lol
Edited by Shepherd on 02-05-18 01:19 PM. Reason for edit: No reason given.
427_4speed
427_4speed
Reg: 01-31-03
02-05-18 01:22 PM - Post#2723449
Black electrical tape or duct tape? LOL
02-05-18 02:49 PM - Post#2723458
Black, better blocker.
2plus2
Loc: Mission,BC
Reg: 02-03-05
02-05-18 03:24 PM - Post#2723461
Leave the fuse in
Unplug the front wheel sensors
Then desolder the led from the cluster
69 Canadian Pontiac 2+2
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
02-05-18 06:11 PM - Post#2723471
Do the GMT-800 trucks have a way to proportion the braking front to rear? On my GMT-400 it's handled by the ABS system. If I pull my fuse, the rears lock up super easy.
The normal fix for the problem is to replace the hubs and sensors..... sensors are replaceable, but often break off. That's what mine did.
99 K3500 RCLB
nickmac
nickmac
Loc: Tennessee
Reg: 02-13-07
02-06-18 04:21 PM - Post#2723568
    In response to 454cid
I pulled my sensors and cleaned everything up and replaced everything. Haven't had any trouble since.
Dan
'16 Chevy Traverse 3.6 FWD
'04 Chevy K1500 Silverado 5.3 4x4
02-06-18 04:49 PM - Post#2723574
    In response to nickmac
I've fixed a few like that, cleaned up the rust on the mounting surface, but most have broken on the way out.
minitruck83
Loc: florida
Reg: 12-21-04
02-20-18 04:33 PM - Post#2725028
    In response to 2plus2
Will unplugging the sensors cut out that dammed warning bell? I can live with the lights on, but that bell drives me crazy.
Pulling the fuse kills my speed control.
2003 1500 LT Burb.
I aint the man I used to be.... Never was.
02-20-18 05:06 PM - Post#2725033
    In response to minitruck83
Find the chime under the dash and unplug it.
minitruck83
Loc: florida
Reg: 12-21-04
02-20-18 09:14 PM - Post#2725055
The chime is routed through the radio.
02-21-18 06:26 AM - Post#2725090
Yikes, didn't know that!
minitruck83
Loc: florida
Reg: 12-21-04
02-21-18 01:26 PM - Post#2725123
Yeah, it really attracts unwanted attention in the Walmart lot!
Sensors (new) give me 348mV and 345mV when the hub is spun, sensor base on hub sanded and cleaned, all grounds checked, no mud in hub.
Guess I'm goinG to have to try unplugging the sensors and see what happens.
(or find a 10 yr old to reprogram it)
02-21-18 05:44 PM - Post#2725134
In my shop when we run into an owner who wants this issued pinned down, we get an abs scanner on it with a driver and co pilot we duplicate the condition and look closely at sensor inputs at low speed, we usually see one drop out at low speeds, this causes the abs to activate. Usually this is a front one that is bad.
wreckmech
Loc: Parsippany, NJ
Reg: 10-08-02
02-22-18 02:08 PM - Post#2725249
+1 on this. I have done many, and by the time I was done I ended up just changing out the wheel bearings. I know this seems like overkill, but I have never had someone come back after I installed Timken bearings.
I have had issues with different manufacturers wheel bearings, as well. This issue can be maddening until you get it figured out. Good luck...
02-22-18 03:06 PM - Post#2725257
    In response to wreckmech
Should also be noted there's a TSB for ground issues near the ABS module. Check the frame rail near the module for this ground.
And as silly as it sounds, don't overlook your brake fluid level. If it's a little bit low it will chime like crazy and give you the vague SERVICE BRAKE SYSTEM error message, lighting up the dash, etc.
Normally I would not advise adding brake fluid unless circumstances required it like you just fixed a leak, bled the system, etc. because under normal operation when you go from new pads/shoes and a full master cylinder, the linings wear with use, the fluid level goes down. You leave it alone. Later when you do new pads/shoes the fluid level goes back up. If you had added any in the meantime, you'll likely now overflow the reservoir and make a mess.
Somehow recently I dealt with the fluid getting too low on my truck although the pads/shoes still have plenty of life left, and there are no leaks in the system. All I can guess is that it was marginally low to begin with from the previous owner and I just hadn't noticed. I got all the warnings and chimes and it turned out I was just a little low on fluid.
minitruck83
Loc: florida
Reg: 12-21-04
02-22-18 04:16 PM - Post#2725268
The problem comes and goes, when the light is on brakes work fine, but when the light is off the chime go's crazy. At 5 mph, the steering wheel will pull to the left (thinking that means the right side sensor is bad, but it reads close to 3.5V. when tested with a voltmeter while spinning the rotor.
I can see why some folks hate ABS, it can be dangerous!
grounds under the battery and the one on frame near the ABS pump are good, also one on rear of engine, there's a couple three more, but they shouldn't affect braking. Will check them anyway.
Edited by minitruck83 on 02-22-18 04:24 PM. Reason for edit: No reason given.
LMC Trucks
Execution time: 0.461 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:38 PM
