Username Post: Cam Gear noise        (Topic#349511)
garykrig
Reg: 02-05-18
02-05-18 10:13 AM - Post#2723433
I recently had the timing gears replaced in my 53 with a power glide. the engine sounds fine at idle but as I rev it up it sounds like a rubbing noise, as the rpm increase the noise goes away. The only thing I can think of is the cam was not pressed on with the right clearance between the gear and the thrust plate,or I have also read where the cam needs to be aligned with the crank shaft with thrust plate gaskets. I am trying to figure out what may be wrong before it has to be tore down again.
02-05-18 01:09 PM - Post#2723446
    In response to garykrig
Welcome to CT. Did this noise start after the work was done?
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
02-05-18 05:17 PM - Post#2723468
I answered this question early in another thread.
02-05-18 05:34 PM - Post#2723470
    In response to cbmkr56
Didn't see that one, doesn't mean you couldn't answer me!
Edited by Shepherd on 02-05-18 05:37 PM. Reason for edit: No reason given.
bobt
Loc: colonial heights va
Reg: 06-28-14
02-06-18 03:30 AM - Post#2723497
Did you try removing the fan belt and running the engine to see if the noise is still there? bobt
garykrig
Reg: 02-05-18
02-06-18 05:40 AM - Post#2723506
    In response to bobt
Yes I ran it without the belts. I am positive it is the cam gear. I am going to pull the fuel pump tonight to see if and how much it moves, Thank You
garykrig
Reg: 02-05-18
02-06-18 05:55 AM - Post#2723507
Yes, the noise started after the work was done. Some teeth came off the old fiber gear. I asked the mechanic yesterday if he checked the alignment of the crankshaft and the thrust plate, his reply was he checked it after the gears were installed. I am pretty certain that is where the problem is.
2blu52
2blu52
Reg: 03-12-02
02-06-18 06:09 AM - Post#2723508
How did he clean up the loose tooth material?
THOMAS JEFFERSON
garykrig
Reg: 02-05-18
02-07-18 05:04 AM - Post#2723609
    In response to 2blu52
Pan was removed and everything was cleaned up.
2blu52
2blu52
Reg: 03-12-02
02-07-18 05:07 AM - Post#2723611
Good!
THOMAS JEFFERSON
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
02-09-18 07:32 AM - Post#2723865
If the later style thrust plate (with the spacer ring) was used adding gaskets is not necessary. Also adding gaskets (or not) will ot cause the gears to rub on anything.
Was the steel gear replaced? If not the noise could be coming from it having worn teeth. The steeth get a wear pattern from the old fiber gear.
Also if the front mount plate was not removed the oil slot on the back of the plate may be plugged with sludge (usually is that is why original gear fails). When it is plugged the timing gears get no lubrication.
Rustchips
Rustchips
Loc: DFW Texas
Reg: 02-24-05
02-09-18 11:27 AM - Post#2723885
    In response to Gene_Schneider
Good Point
1928 Chevy Coupe
1955 Chevy Bel Air HTP
1970 El Camino
1990 F##d Mustang Convertible
garykrig
Reg: 02-05-18
02-11-18 07:39 PM - Post#2724120
Both gears are new. I pulled the fuel pump this morning and tried to move the cam, it would not move. I told the mechanic to check to make sure nothing was plugged because I suspected lack of lubrication may have caused the problem. I am quite he did not check behind the plate.
Execution time: 0.162 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:15 AM
