Username Post: Tach lens        (Topic#349457)
rick1965
Loc: joliet ill
Reg: 12-07-16
02-01-18 05:47 PM - Post#2723028
So finally found a tach for my 65 ss.after over 50 years of well intensioned cleanings,the lens is kinda hazy. Any ideas on how to polish it without making it worse? Or is there anything in the repop market yet?
MostWanted
MostWanted
Reg: 04-11-16
02-01-18 06:50 PM - Post#2723030
    In response to rick1965
Contact ChrometechUSA. Maybe Bob will tell you how he polishes the ones he gets or maybe you can send yours to him.
1965 Impala SS
Black/Red; 327ci (Original); ZZ6 350ci GM Crate Motor (Current) with 405hp & 405 ft/lbs torque; Wilwood four wheel disc brakes; Wilwood master cylinder & proportioning valve; Ridler 20x10 rears & 18x8.5 fronts; Retrosound Model 2
bigbowtielover
bigbowtielover
Loc: Surrey British Columbia
Reg: 09-01-13
02-01-18 07:22 PM - Post#2723032
You can use the lens from a vacuum gauge.
Texasray
Texasray
Reg: 11-01-16
02-02-18 10:49 AM - Post#2723084
    In response to bigbowtielover
Find a shop in your area that sell Plexiglas, polyethylene or Kydex sheets to businesses. Regal Plastics is our local supplier. They should have several plastic cleaners in various grits for polishing Plastic, I can't find any around here right now to give you a brand name but the stuff works awesome.
Sam
66 Impala L-C
Loc: Marietta, OH
Reg: 02-24-09
02-02-18 05:49 PM - Post#2723130
Check with your local motor cycle shop. They have products to clean and remove scratches from wind screens.
Gaspains
Gaspains
Loc: Mankato, MN
Reg: 11-23-09
02-03-18 06:45 AM - Post#2723177
    In response to 66 Impala L-C
Maguire’s Mirror Glaze has always been my go to plastic restoration product. They make it in cleaner and polish.
First heard of it being used on airplane Plexiglass wind screens. Also motorcycle screens. Have even used it on plastic eyeglass lens. And a bowling ball, but that’s a different story.
Kevin
1965 Impala SS Coupe
Regal Red with Black Interior
L74 327
M-20
3.31 One-wheel wonder, 12 bolt
65-66 FSCC #512
rick1965
Loc: joliet ill
Reg: 12-07-16
02-05-18 12:13 PM - Post#2723436
went in to the harley shop near here and they use a product from novus- heavy scratch remover made for plastics. i tried it and after three rounds of polishing it works. cleared it up pretty good.the lens from my old vac gauge looks a little better but this will do.
"14th Year" Platinum Supporting Member & Moderator
02-06-18 02:08 PM - Post#2723549
Novus is a great product. Mil Spec and used on military aircraft canopies and windscreens.
Oshawa65SS
Loc: Burnaby BC Canada
Reg: 09-22-14
02-06-18 11:53 PM - Post#2723606
    In response to 427SS65
I bought 3 bottles of Novus years ago.
#1 is a spray for finishing and cleaning, #2 is for fine scratches, and #3 is for heavy scratches, but if you can feel a scratch with your fingernail forget it when it comes to hand polishing hard plastic with Novus.
Always seemed weird to me that #2 is a tan color compound that seems coarser or more effective than the #3 that is a white color compound?
Maybe the bottles got filled wrong?
Ryan
65 Impala SS convertible 283 2V with Powerglide and 10 bolt 3.08 open
Build date Dec. 21 '64 Oshawa
66 Impala L-C
Loc: Marietta, OH
Reg: 02-24-09
02-07-18 07:44 PM - Post#2723702
I got mine at the Harley shop. It is the Novus 2 for fine scratches. It did take several times over the lens. Doesn't look just out of the box brand new but looks real good.
02-08-18 02:44 PM - Post#2723779
    In response to Oshawa65SS
Ryan, for the bad scratches, I use Comet cleanser with a little water to make a paste, or even toothpaste. If the scratch is bad bad, then wet-or-dry sandpaper is in order (400-2000 grit) before polishing out.
Oshawa65SS
Reg: 09-22-14
02-08-18 09:00 PM - Post#2723828
Thanks Tom, I had scratched and scuffed factory optional door speaker grills on the Mustang and used 0000 steel wool to start.
It left them smooth and dull, then the Novus polish brought them back shiny.
Ryan
Execution time: 0.347 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:35 PM
