41 Years of Service
Username Post: Tublar A-Arm Torque specs        (Topic#349439)
showvell_69
Reg: 04-07-14
01-31-18 07:03 PM - Post#2722915
I purchased a set of front upper and lower totatly tubular A-arms (5864TCA-UKS and 5864TCA-LKS) for my 61 Impala. Can you tell me what the touque specs are for the cross shaft end bolts for the upper and lower units? Also, what is the torque specs for the tubular rear uppper and lower trailing arms to frame and rearend?
1969 Chevelle
1967 Camaro
1965 Buick Riviera
1961 Impala (In-work)
cpptech
cpptech
Loc: CA. USA
Reg: 12-08-06
02-14-18 03:31 PM - Post#2724410
    In response to showvell_69
The front control arms are already lock tite and torqued on the cross shaft, do not loosen or tighten these.
The rear torque spec is same as the factory arms you could find this info in a factory service manual.
Thanks,
Aaron @ Classic Performance
800-522-5004
showvell_69
Reg: 04-07-14
03-05-18 04:36 PM - Post#2726545
    In response to cpptech
I disassembled the front upper and lower A-arms from the cross shaft to powdercoat them. Upon reasseamby, what torque specifications do you suggest?
1969 Chevelle
1967 Camaro
1965 Buick Riviera
cpptech
cpptech
Loc: CA. USA
Reg: 12-08-06
03-12-18 07:14 AM - Post#2727299
As mentioned in the above post we do not want these disassembled. They are installed with red locktite and tightened down when we assemble them. being that you did take them apart I would reference any general torque spec sheet you can find regarding the grade 8 bolt.
Thanks,
800-522-5004
Execution time: 0.424 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:59 PM
