Username Post: Starter removal        (Topic#349237)
Old Chevy Soldier
Old Chevy Soldier
Loc: Central Montana
Reg: 03-12-12
01-19-18 05:12 PM - Post#2721528
1990 square box Caprice with rear sway bar and cross member supports. Can,t seem to find a hole big enough to drop the starter out. Does the cross member support need to be removed?
Life is to short to ride an ugly horse or drive a Ford
Impala65SS
Impala65SS
Loc: Sweden
Reg: 08-23-07
02-11-18 01:00 PM - Post#2724077
    In response to Old Chevy Soldier
Sorry for late answer, but as far as I can tell - no. even though I'm not clear on what you mean by crossmember support. The only "unboltable" crossmember I can think of would be the tranny crossmember.
Did some work on my brother's '85 (with the optional rear swaybar - f41 I think) it had no problems getting the original starter out. I happened to replace it with a ministarter I had lying around.
http://www.youtube.com/watch?v=SXn2QVipK2o&a mp;fea...
Old Chevy Soldier
Old Chevy Soldier
Reg: 03-12-12
02-17-18 10:08 AM - Post#2724683
    In response to Impala65SS
Thanks for the reply. I replaced the starter. The support is a bolt on frame brace that runs diagonally from the frame rail to the front crossmember, directly under the starter. From what I've found on the internet, these braces were put on at the factory as part of a suspension upgrade package.
Thanks again, Tim
Execution time: 0.237 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:49 AM
