Username Post: Ignition switch question        (Topic#349154)
78elk
Reg: 12-23-08
01-14-18 02:07 PM - Post#2721028
I have a problem with my ignition switch on my 78 El Camino. When starting the car,I turn the ignition switch, which hits a point of resistance. I continue and the car starts. I then have to turn the switch backwards till it gets past the same point of resistance. What's going on here so I have to go through this routine? The car runs fine and I've been trying to find the answer to stop this from happening.
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
01-15-18 05:02 AM - Post#2721080
    In response to 78elk
More than likely its the lower ignition switch itself. It does have a return spring built into it.
78elk
Reg: 12-23-08
01-17-18 11:49 AM - Post#2721287
    In response to junkman104
Yes, and it's been doing it since it was new.
78elk
Reg: 12-23-08
01-23-18 02:32 PM - Post#2721881
When the ignition cylinder is in the Acc setting, should the key line up with the lock position?
