Username Post: 03 silverado oil leak        (Topic#349148)
Bob Baum
Loc: michigan
Reg: 10-26-12
01-14-18 04:31 AM - Post#2720990
my 03 Silverado started to leak fluid from
the right front axle I hear it is a common
problem how much of a job to fix any ideas
thanks
Bob B
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
01-14-18 06:10 AM - Post#2720997
    In response to Bob Baum
https://youtu.be/SGnWVNrbX8M
Bob Baum
Loc: michigan
Reg: 10-26-12
01-14-18 06:24 AM - Post#2720998
    In response to junkman104
good information thanks
Bob B
george88gta
george88gta
Loc: new york
Reg: 04-23-03
01-15-18 02:38 PM - Post#2721112
Depends on your mechanical ability. Pretty straightforward, be sure to use a heavy grease to keep the thrust washer( number 9 in the diagram ) in place during assembly. Easily accomplished in a few hours.
Attachment: axle.pdf (164.35 KB) 21 View(s)
Edited by george88gta on 01-15-18 02:39 PM. Reason for edit: No reason given.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
01-16-18 09:32 PM - Post#2721244
    In response to george88gta
some of them had a redesign in the retainer that holds the shaft into the housing.
Horrible design in my opinion.
the shaft wears on the clip and next thing you know there is nothing clipping the shaft in causing it to ride in the housing.
There is also a redesign in the seal. Much better design. attaches to the housing and the shaft. Should ensure no further leaks
Old School GM fan FOREVER
Edited by rockfangd on 01-16-18 09:33 PM. Reason for edit: No reason given.
Bob Baum
Loc: michigan
Reg: 10-26-12
01-17-18 05:23 AM - Post#2721251
    In response to rockfangd
I would guess go to my GM dealer and get the
correct seal any advice ?
george88gta
george88gta
Loc: new york
Reg: 04-23-03
01-17-18 06:00 AM - Post#2721252
The GM part is a good choice. It also is greased so if you forget to lube the shaft, you wont get a dry start. I would also get a new thrust washer.
Bob Baum
Loc: michigan
Reg: 10-26-12
01-18-18 04:03 AM - Post#2721355
ok thanks
Execution time: 0.264 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:59 PM
