Username Post: Key on and start 12v        (Topic#349142)
lowblazer
Reg: 02-02-16
01-13-18 05:42 AM - Post#2720929
Been lurking in the forum for a long time. I have gained so much knowledge. I have a 1960 Bel Air 4 door. 283/PG. I have been doing different upgrades, and currently I am finishing up a Sniper EFI. I am having a hard time finding a wire that has 12v on key on, and key start. Can anyone here assist me with this? My name is Eric by the way!
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
01-13-18 06:02 PM - Post#2720973
    In response to lowblazer
What are you using for a distributor?
Your + coil wire would have what you are looking for, unless you are using stock points. Then there is a resister wire in the harness.
You should also find a connection on the fusebox powered on by the key, if that is stock.
Member #2194
lowblazer
Reg: 02-02-16
01-13-18 08:13 PM - Post#2720984
    In response to DonSSDD
Thanks for the reply. It is still the stock points style distributor. I have checked the fuse panel, and I can find key on 12v, but not a source that is 12v on key on AND key start.
DonSSDD
DonSSDD
Reg: 08-21-01
01-14-18 04:49 AM - Post#2720991
Run one off the ignition switch wire that runs to the coil + side. At the ignition switch it puts out 12V, before it goes into the wire harness where the resistor resides.
Member #2194
Edited by DonSSDD on 01-14-18 04:50 AM. Reason for edit: No reason given.
JayChicago
JayChicago
Loc: Chicago
Reg: 01-03-13
01-17-18 09:56 PM - Post#2721351
There is no one place on your car where you can get +12V in both KEY-ON and START modes. The car was designed to keep those two circuits isolated from each other. And if you come off a source in each circuit and then join them together to feed your EFI, each circuit will back-feed the other and cause problems. (like the starter continuing to run in KEY-ON)
I would think you should talk to the EFI supplier; seems like they would have figured out an easy solution. It probably needs to be done using one or two relays. (when a relay springs open, it prevents back-feeding into its circuit)
Another point: To be safe you want your new +12V feeds to be fused. The ignition switch on our cars is ahead of the fuses, so not a good source. The fused source you found at your fuse panel would be good for KEY-ON. And on our old cars the START circuit does not go thru the fuse panel, it is not fused at all! So nothing lost if you tap the START circuit at the ignition switch, but your new feed should then have an in-line fuse within the first few inches.
Execution time: 0.256 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:04 PM
