Username Post: Key on and start 12v        (Topic#349142)
lowblazer
Reg: 02-02-16
01-13-18 05:42 AM - Post#2720929
Been lurking in the forum for a long time. I have gained so much knowledge. I have a 1960 Bel Air 4 door. 283/PG. I have been doing different upgrades, and currently I am finishing up a Sniper EFI. I am having a hard time finding a wire that has 12v on key on, and key start. Can anyone here assist me with this? My name is Eric by the way!
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
01-13-18 06:02 PM - Post#2720973
    In response to lowblazer
What are you using for a distributor?
Your + coil wire would have what you are looking for, unless you are using stock points. Then there is a resister wire in the harness.
You should also find a connection on the fusebox powered on by the key, if that is stock.
Member #2194
lowblazer
Reg: 02-02-16
01-13-18 08:13 PM - Post#2720984
    In response to DonSSDD
Thanks for the reply. It is still the stock points style distributor. I have checked the fuse panel, and I can find key on 12v, but not a source that is 12v on key on AND key start.
DonSSDD
DonSSDD
Reg: 08-21-01
01-14-18 04:49 AM - Post#2720991
Run one off the ignition switch wire that runs to the coil + side. At the ignition switch it puts out 12V, before it goes into the wire harness where the resistor resides.
Member #2194
Edited by DonSSDD on 01-14-18 04:50 AM. Reason for edit: No reason given.
Execution time: 0.352 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:27 AM
