Username Post: 82 gmc 305        (Topic#349141)
ChanceGamble
Reg: 01-13-18
01-13-18 03:50 AM - Post#2720924
So I pulled into the gas station turned the beast off and pumped me some of that raw poopoo and when I turn her on no headlights just brights??? Take all the help I can get cause I ain’t no mechanic lol preciate it
Edited by ChanceGamble on 01-13-18 03:55 AM. Reason for edit: No reason given.
LMC Truck
Stinky
Loc: Whitewater, CO
Reg: 05-25-01
01-13-18 08:29 PM - Post#2720985
    In response to ChanceGamble
So....you have brights....those are headlights.
Check your fuses. If they are OK, then change your headlights.
Senior Chevytalk Moderator
01-15-18 05:57 AM - Post#2721087
    In response to Stinky
Welcome to the site. Is the high beam switch on the floor or column? The floor switch over time does rust. Step on it a couple of times. Mine cuts off lights. After stepping on it several times, it starts to work correctly.
LMC Truck
Execution time: 0.245 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:42 AM
