Username Post: Gen.VI 454 cam end play?        (Topic#349136)
Am4wag
Reg: 11-19-15
01-12-18 09:04 PM - Post#2720904
Put the cam in,bolted up retainer plate,mounted cam sprocket and tightened sprocket to cam.I can turn it with one hand,but surely it should have some end play.I did a measurement and from what it looks like I have .002" of preload on the Torrington....Maybe make a shim to put between the sprocket and cam mounting boss'?How much end play does it need?
The bearer of gossip is a small untrustworthy person who takes delight in someone else's problems. Avoid them.
Let's all make the day count. - Charlie Daniels
Edited by Am4wag on 01-12-18 09:05 PM. Reason for edit: No reason given.
01-13-18 10:53 AM - Post#2720945
    In response to Am4wag
.010 should do it.
Edited by Shepherd on 01-13-18 10:53 AM. Reason for edit: No reason given.
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
01-13-18 01:10 PM - Post#2720953
I was thinking my cam card told what it should be.
Jeff
'88 Chevy K3500, aluminum head roller cam 511inĀ³ stroker 10.5:1 compression, 96 NV 4500, 94-98 grille, 305/70-16 (33x12) BF Goodrich KM2s, 91 cluster swap
01-13-18 01:43 PM - Post#2720957
    In response to bowtie44s
Usually a roller cam is subject to screwing it self forward, if you have one it might be on the cam card. But .010 is what I aim for.
Execution time: 0.338 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:22 AM
