Username Post: Do I have the proper battery?        (Topic#349122)
Brian D from NJ
Brian D from NJ
Loc: Riverside, New Jersey
Reg: 04-28-04
01-11-18 06:39 PM - Post#2720826
I've been having starting issues since about the middle of last year.
My B.A. is garage kept. When I've gone out to the garage to start it all I get is a "click" (starter/relay/other electrical?). When I check the battery, it's discharged. I put the charger on it and it comes right back and holds the charge.
When I try to start it again, nothing back to the click. And the battery shows discharged again.
The engine does not want to turn over. The battery is two years old. The tag on it shows 800 CA amps at 32 degrees and 650 CCA amps at Zero degrees.
Could there be an electrical problem drawing the battery down? The electrical system is stock in this car.
Just because your car/truck was "Made In America" doesn't mean it's American made... think about it. Buy American First.
YOUNG57
Loc: Tennessee
Reg: 12-06-10
01-12-18 06:54 AM - Post#2720844
    In response to Brian D from NJ
It may be a bad battery but…
Do you know if the generator/alternator is charging? Check the generator/alternator’s output while the engine is running with digital volt meter, it should 14 + volts at the battery.
As a test to see if there is a drain on the battery remove the battery’s negative cable after you shut it off for the day and see if it lost its charge or will start the next day.
Brian D from NJ
Brian D from NJ
Reg: 04-28-04
01-12-18 09:33 AM - Post#2720857
    In response to YOUNG57
Thanks. Next thing I'm checking.
01-12-18 09:47 AM - Post#2720859
How long between charging it enough to start the engine and when you try to start it again?
Yes, you could have something drawing the battery down. Try disconnecting the battery until you try to start it again, and see if it's run down.
A fast charge may bring the battery back up, but it may not be fully charged. Try a slow charge for several days.
pauldian
pauldian
Loc: seligman,arizona
Reg: 05-14-09
01-12-18 10:47 AM - Post#2720863
The first thing I would do is to clean the battery post and where the ground wire is connected, charge the battery and go from there.
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
01-12-18 07:26 PM - Post#2720896
The battery could be bad. Have it tested.
You could have a curent draw. Remove cable test as suggested.
A bad battery cable or bad connections possible.
Brian D from NJ
Brian D from NJ
Reg: 04-28-04
01-13-18 07:39 PM - Post#2720979
    In response to Gene_Schneider
Hi Gene, I'm going to do some of the suggestions mentioned here. I have no heat in the garage. It was zero to negative 4 a couple of days last week . Of course, it was about 64 here yesterday (Friday). I'll have to get some fuel for the torpedo heater.
Just as an aside, I did bring the battery indoors to charge it. Placed it on the kitchen floor. (Haven't heard the last of it from the girlfriend!)
I'm going take it to Autozone to get it checked this week.
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
01-13-18 08:06 PM - Post#2720983
It can be dangerous to charge a battery in a confined area.
Execution time: 0.165 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:28 AM
