Username Post: Moser Engineering        (Topic#349116)
Mick53
Platinum Supporting Member
Mick53
Loc: Northern Indiana
Reg: 04-02-16
01-11-18 06:50 AM - Post#2720765
I bought a used Frankland rear end for my 53 1/2 ton pickup. I took it to the Frankland factory in PA to have it rebuilt with Gleason locker and retubed with 12 bolt flanges to fit under my truck. They would not get axles for me. They told me to call Strange Engineering. I called Strange and explained to them that I needed axles to accept 12.88 Wilwood disk brakes. They told me that they could not help me until I filled out an online form. It wanted information I had no idea about such as axle diameter and bearing size. When I explained to them I had no axles to start with they were kinda rude to me. So I called the engineer at Wilwood (Erik) that I have been working with and he suggested I call Moser. It turns out that they are only 2 hours from my house. When I called Moser they said no problem and If I could get it there by 8am any day that they should be able to get it done by that afternoon. I loaded up the rear end and the brake kit so everything would be right and planed to leave the next morning at 6am. That night we had 4" of snow and freezing rain. It was almost 10am by the time I got there. When I backed the truck in to drop it off they discovered that Frankland had put the wrong flanges on and welded them on backwards, inside out. I asked them if they could fix it or send it somewhere to get it right. They asked me to wait a little while and they would check it out. At about 11am they told me they could replace the flanges and have me done around 3pm if I wanted to wait. So I went in town and killed some time. By 2pm they had removed the old flanges and welded on new ones. They had the axles done also. Then they took me out to the shop and installed one of the brakes to show me how they went. There were some bolts that the kit called for using existing bolts that I didn't have. They had the special flange bolts. Also the roter holes had to be enlarged for the studs. By 3pm I was on the road. They charged me an extra $100 for the flanges, bolts and extra labor. More than fair in my mind. In this day and age it is very seldom that I get this kind of service. I would highly recommend Moser for anything they do.
01-11-18 07:13 AM - Post#2720767
    In response to Mick53
Very nice, always good to hear about a vendor/shop that has a can-do attitude and gets things handled for you.
55 Shaker
Loc: north central IL.
Reg: 03-13-06
01-11-18 09:05 AM - Post#2720772
Back in my drag racing days, I did business with Moser Engineering. They treated me well, and their pricing was fare. I would have no problem recommending them either.
Brian
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
01-13-18 08:40 PM - Post#2720980
That's first rate service. The honorable thing was done. Kudos, Moser.
Greg
'00 Explorer XLT 4.0 V6 Auto
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
01-19-18 08:15 AM - Post#2721483
    In response to CowboyTrukr
it sounds like the guys at moser will be getting my future business
Ive dealt with far to many people that cop a "I JUST DON,T GIVE A S^&^&& attitude if they can,t simply grab something off a shelf
Execution time: 0.272 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:06 AM
