Username Post: MAP question        (Topic#349102)
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
01-09-18 09:13 PM - Post#2720643
I do not know much about the metric system and therefore I avoid it. The English system works great for me but my MAP sensor reads in metric. What is it reading in? I thought KPA but everything I look up says KPA is pressure. I have an Autometer vacuum gauge that reads in good old inches of mercury. When I floor it, the vacuum drops to 0 inhg but the MAP goes to 100.
Is it a different way of measuring the same thing? How do you convert one to the other?
Jeff
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
01-10-18 12:17 AM - Post#2720651
    In response to bowtie44s
I had to look up MAP sensor, for some reason I thought you were talking about the MAF, at first.
You're vacuum gage is telling you "gage" pressure, which is zero at your local air pressure. The MAP sensor measures "absolute" air pressure, which is measured against a true 0 pressure. 1 atm (atmosphere) is about 30 inHG, and 30inHG is about 100 Kpa.....not exact, but ball park. So your two readings are the same, but in two different units and from two different reference points.
99 K3500 RCLB
Edited by 454cid on 01-10-18 12:22 AM. Reason for edit: No reason given.
01-10-18 05:45 AM - Post#2720664
If you are using a scanner, go to settings and switch to english.
65_Impala
Reg: 12-29-02
01-10-18 07:29 AM - Post#2720675
Same reading, just different scales.
MAP is pressure referenced to absolutely no pressure. So, 100kPA is ~standard~ atmospheric pressure. It's made with a pressure sensing element that basically has the engine vacuum on one side and a complete vacuum on the other side. So, no engine vacuum at WOT reads higher than having engine vacuum at idle because the atmosphere is passing into the intake and to the sensor and then pressing on the element when there is no engine vacuum.
Historically, vacuum was first measured in reference to the atmosphere using a manometer. A U shaped tube with mercury in it, one end open to atmosphere and the other end being sucked on by the vacuum. The height the mercury lifted was equated to the amount of vacuum, hence the "Hg (inches of mercury) as the units. The tools to measure vacuum improved, but the units stuck.
It's not an simple one step multiply or divide conversion.
To do it take the MAP reading, divide by 100, multiple by 29.61 and then subtract 29.61.
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
01-10-18 08:30 AM - Post#2720680
    In response to 65_Impala
Thank you. Using your formula, my 47 at idle converts to -15.6 which is about where I'm reading in inhg.
Jeff
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
01-10-18 12:20 PM - Post#2720699
Could you explain where your formula is coming from? It's not making any sense to me, and I'm pretty good with units.
99 K3500 RCLB
Edited by 454cid on 01-10-18 12:43 PM. Reason for edit: No reason given.
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
01-10-18 07:06 PM - Post#2720726
    In response to 454cid
It works, I compared my map to my vacuum gauge at a few different places and his formula works.
Jeff
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
01-10-18 08:48 PM - Post#2720747
I guess he's just using the 100 to shift the decimal place. The number 29.61 doesn't match what I can find, However. It's a bit off, and isn't due to rounding. Probably close enough for our purposes.
What exactly are you doing?
99 K3500 RCLB
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
01-11-18 08:48 AM - Post#2720776
I am guessing the 29.67 is normal barometric pressure. Ours is currently 30.02 so I'm just guessing that's where some discrepancy could be.
I have a FiTech TBI and the handheld has map readings. I have had a vacuum gauge for a long time. I was just wondering how the two correlate.
Jeff
65_Impala
Reg: 12-29-02
01-11-18 06:03 PM - Post#2720820
I just threw out a number that I though was the reading for a vacuum. To be more precise consider the following.
0kPA is 0 atmospheres and 100kPA is 0.986923 atmospheres.
Engine vacuum is considered -29.92 "Hg at 0 atmospheres and 0"Hg at 1 atmosphere.
This means the vacuum changes by 29.53"Hg as you go from 0 to 100 kPA.
So, a more accurate formula should be something like this.
Figure out the percentage of kPA by dividing the reading by 100kPa.
Multiply the percentage by 29.53 "Hg to get the amount it's away from a total vacuum in "Hg.
Add the amount it's away from a vacuum to -29.92 "Hg.
You do have to decide if you want the vacuum reading to be positive or negative. I'm giving a value that is more negative for more vacuum.
You have to be careful of what standard pressure the reading are referencing or comparing to. The MAP reading is the pressure above a vacuum. The "Hg used in a car is how much the mercury falls on the side of the manometer open to a 1 atmosphere standard atmosphere when the manifold vacuum sucks on one side of the manometer.
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
01-11-18 08:42 PM - Post#2720832
Wow, to me, that's making it way more complicated than it needs to be. I don't understand why you want to use a percentage.
MAP kpa x .2953inHg/1KPA - 29.9213 inHg (or local pressure) = gage pressure inHg
99 K3500 RCLB
Edited by 454cid on 01-11-18 08:55 PM. Reason for edit: No reason given.
65_Impala
Reg: 12-29-02
01-12-18 03:02 PM - Post#2720880
No, the long form is just explaining where the calculation comes from.
It's not like the formula MAP divided by 100 x 29.53 - 29.92 is so much more difficult to calculate.
29.52 divided by 100 is 0.2953, so you just hid the divide by 100 into the formula.
Execution time: 0.165 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:09 AM
