Username Post: Torque converter selection        (Topic#349089)
LSS1333
Reg: 05-13-15
01-09-18 09:46 AM - Post#2720560
Need help choosing torque converter and stall speed.
I have a 63 impala converter (probably close to 4000 lbs).
TH 350 transmission.
3.08 rear gears.
383 sbc roller cam, aluminum heads with about 415hp/430tq
Lunati 211/219 cam with .510/.515 lift @ .050
Nice street cruiser
01-09-18 10:03 AM - Post#2720562
    In response to LSS1333
Missing a big piece of the equation, diff gear ratio, and tire size?
LSS1333
Reg: 05-13-15
01-09-18 10:07 AM - Post#2720563
differential 3.08
tire size approximately 27in tire
01-09-18 02:09 PM - Post#2720585
Educated guess with most convertor selections, too loose won't lockup till you are over 60, with that combo. I have about the set-up same in my 51 Belair sbc. Mine is around 2100, my car is way lighter than yours, but you make much more torque. I'd say 22-2400, but convertor ratings vary based on engine power.
Edited by Shepherd on 01-09-18 02:10 PM. Reason for edit: No reason given.
LSS1333
Reg: 05-13-15
01-09-18 03:14 PM - Post#2720593
Thanks Shepherd,
I was thinking 1800-2000 stall, but the transmission comes with a 2500 stall. Was worried that 2500 might be too loose for my set up?
01-09-18 04:49 PM - Post#2720605
If it is truly 2500, agreed too loose and you would be what is called driving on the convertor to at least 60.
rumrumm
rumrumm
Loc: Macomb, IL
Reg: 10-18-01
01-10-18 10:45 AM - Post#2720690
Call a couple of converter manufacturers and speak with one of their technicians--see what they recommend and report back.
Lynn
"There's no 12-step program for stupid."
383 sbc, Eagle, AFR, SRP, CompCams, Edelbrock, FiTECH. Dyno #'s: 450 hp @ 5700, 468 ft. lbs. torque @ 4300.
http://photo.net/photos/Lynn%20Johanso n
65_Impala
Reg: 12-29-02
01-11-18 06:14 PM - Post#2720822
If you get that 2500 rpm stall converter with the transmission and can't avoid receiving it, then why not try it first?
Execution time: 0.181 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:50 PM
