Username Post: Code 13... O2 sensor        (Topic#349082)
Ralph0000001
Reg: 01-09-18
01-09-18 06:24 AM - Post#2720537
Have a code 13... open circuit O2 sensor... is 3 wire upstream... changed sensor... and cleared by disconnecting -cable on battery while changing sensor... still have code 13 coming up... ? Anyone have idea what's wrong?
1994 Chevy 4x4 standard 4spd cast iron... 6 bolt wheels... was a 6 cyl... bought it with a 305... put a 95 5.7L in her...
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
01-09-18 06:42 AM - Post#2720540
    In response to Ralph0000001
Welcome to ChevyTalk, Ralph.
Just as a quick housekeeping suggestion, it is wise to add your truck information in your signature space. Truck year, model, engine, and transmission info. Also, is your truck stock?
Greg
'00 Explorer XLT 4.0 V6 Auto
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
01-09-18 06:50 AM - Post#2720541
    In response to CowboyTrukr
First verify you have 12V at the plug. If you do, then you’ll need to trace the output lead wire back and make sure there’s continuity to the computer. The sensor has power, a ground, and the signal lead.
Greg
01-09-18 07:50 AM - Post#2720548
Agreed, good info
Ralph0000001
Reg: 01-09-18
01-09-18 10:20 AM - Post#2720565
Great... I'll get on that as soon as the big storm is over... thank you 👍✌
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
01-09-18 11:30 PM - Post#2720648
Actually, Ralph, I forgot to clarify: You may have a 3 wire sensor with a built in heater feed.
If yours in only a single wire one, then you only have the 1 wire to trace, obviously.
Greg
Ralph0000001
Reg: 01-09-18
01-11-18 08:31 AM - Post#2720773
Ok... New sensor... checked plug for 12v and ground are good readings... wire from plug to computer plug behind glove box has good continuity... everything checks out as you requested... still have code 13... open circuit O2 sensor... ????
Edited by Ralph0000001 on 01-11-18 08:33 AM. Reason for edit: No reason given.
01-11-18 08:43 AM - Post#2720774
Did you clear the code? Drive it and it came back?
Ralph0000001
Reg: 01-09-18
01-11-18 10:42 AM - Post#2720782
Yes... cleared the code... after running for only a few mins the light came on again... so turned the truck off... and checked codes... same one code 13... I use to have a code 14 also... engine temp sensor... changed it and the code is gone...
Edited by Ralph0000001 on 01-11-18 10:47 AM. Reason for edit: No reason given.
01-11-18 10:53 AM - Post#2720785
At this point you should get a scanner on it and look at sensor activity, see if it is switching as designed. What year is it?
Ralph0000001
Reg: 01-09-18
01-11-18 03:37 PM - Post#2720802
It's a 94 chev 1/2 ton standard 4 speed with bull low... originally had a 6 cycl... bought it with a 305, bought it from a mechanic... can't remember if dash had a light on or not then... 305 died, put a 350 in it... garage done it... this fall it started to fluctuate at idle and lately start to hesitate driving... disconnected O2 sensor, no fluctuations and no hesitation... code 13 and 14 came up... fixed 14... 13 still there after changing sensor and the trouble shooting as suggested... hope this helps...
01-11-18 04:56 PM - Post#2720812
That info may finally help, you need to check for the proper ecu/,pcm. Research the right part numbers, see if the engine matches the pcm. Now that maybe the transitional Obd 1.5 in 94, if not it may have a prom in the ecu that can be changed to match that engine. Gonna have to do some backround research here. Lotta changes were done.
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
01-11-18 05:49 PM - Post#2720818
It's hard to tell what you have. The last year for the SM465 4spd was 1991. Someone probably pulled the motor and transmission out of an older truck. I would bet Shepherd is right and you have the wrong ecm.
Jeff
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
01-12-18 10:26 PM - Post#2720910
    In response to bowtie44s
OBD 1.5 was only an S10 thing in '95 if I remember correctly. The C/K series was straight OBD1 until '96.
Make sure you have the computer and PROM chip that came with the '94 5.7.
Shouldn't be an issue as far as the O2 sensor is concerned, but it makes a difference how the computer treats things.
As Shepherd said, it's time to get a scanning code reader or a laptop, OBD1 USB cable, and a decent program like TunerPro to watch what's going on.
Greg
Execution time: 0.256 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:45 AM
