Username Post: Remove Turn Signal Switch 65        (Topic#349060)
srwhite57
Loc: Tyler, Texas
Reg: 01-10-07
01-07-18 05:01 PM - Post#2720377
This should be simple but we cannot figure it out. We need to replace the turn signal switch and the old one does not want to come out. How does it come out? Any help appreciated. It is a nice 7,000 mile original 65 truck and the plastic switch became brittle and broke.
hilandr451
hilandr451
Loc: Anna Texas
Reg: 01-02-02
01-08-18 11:14 AM - Post#2720444
    In response to srwhite57
This should help: Highlander's 60-66 Chevy Truck Information Site
-The Hilander.
Silver 2017 Silverado 1500 double cab 2WD 5.3L
"Rattle can primer red" 1966 C20 Custom Camper 5.7L, 700 R4 trans 410 diff. front disc, p/s
Project Pics
srwhite57
Loc: Tyler, Texas
Reg: 01-10-07
01-08-18 02:03 PM - Post#2720467
    In response to hilandr451
Thanks for the reply, but the post does not help. My problem is that the switch will not come off the steering shaft. Is there any special trick or is it just supposed to lift off?
hilandr451
hilandr451
Loc: Anna Texas
Reg: 01-02-02
01-09-18 10:15 AM - Post#2720564
can you post a pic? as soon as you remove the screws, it should just lift off the plate.
-The Hilander.
Project Pics
srwhite57
Loc: Tyler, Texas
Reg: 01-10-07
01-09-18 03:12 PM - Post#2720592
Thanks for taking a look. If I were to guess, it looks like the ball bearing is stuck on the shaft.
Oh, the center screw of the 3 that hold the switch in is totally unscrewed, just did not have a magnet to get it out of the hole. It is NOT holding the switch in place.
Edited by srwhite57 on 01-09-18 06:42 PM. Reason for edit: No reason given.
62ss409
62ss409
Loc: London,Ontario. Canada
Reg: 11-17-02
01-10-18 12:29 PM - Post#2720701
I believe there is a clip at bottom of the column that holds the harness. unclip that first, then lift out the switch.
fyi. .. the new switches are not bent proper at the horseshoe clip, you will have to slightly bend it to work properly.
62 SS 409 Conv, 60 Impala Conv, 72 LT-1 Conv, 65 C-10, 92 k10 sportside, 2011 sierra
srwhite57
Loc: Tyler, Texas
Reg: 01-10-07
01-10-18 08:17 PM - Post#2720743
    In response to 62ss409
Thanks for the suggestion. Unfortunately the harness is loose. Maybe I should have mentioned this is for a C50 1 1/2 ton truck. Anyone know if they had different switches for the heaver trucks, or anyone have a parts manual reference that can look it up? Thanks in advance.
joek3167
Loc: MO.
Reg: 05-08-09
01-10-18 08:51 PM - Post#2720748
Switch is the same in the medium duty trucks
64ss409
Reg: 12-04-02
01-11-18 06:44 AM - Post#2720769
With that remaining screw loose, can you remove that switch arm? I would like to see what is under it.
Ron
srwhite57
Loc: Tyler, Texas
Reg: 01-10-07
01-11-18 12:22 PM - Post#2720787
    In response to 64ss409
That is the problem, nothing will come out. I can rotate it a few degrees but it will not lift out.
Execution time: 0.454 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:53 AM
