Username Post: Powerglide reverse        (Topic#349036)
Hards..60
Hards..60
Loc: Northern Ontario,Canada
Reg: 10-20-07
01-06-18 12:12 PM - Post#2720223
Hello gentlemen.
The last time I was on here, I was whining about a shutter or chatter in my transmission when I put it in reverse. Well since then I have removed the transmission and have conducted an investigation as to why. I have included some pictures and would like to know if I`m on the right track, from anyone who has an opinion.
Here`s what I found.......
This is a picture of the pressure regulator valve assembly...reverse booster from my 1960 shop manual.
And this is how it came apart when I removed the cover.....
I believe that the picture shows this.....
The other thing I noticed was that the pin inside this housing which slips into the valve was on in reverse of the picture.....the pin was inside the valve instead of outside as shown.
Now I have some questions.
1) Would this have caused my problem
2) Here`s a picture from the `58 shop manual showing some ``O`` rings...should there have been ``O`` rings on mine....
3) And finally this...
How freely should this pin move. I can push it in with some pressure.
Any input, from anyone would be greatly appreciated.
Thanks.
Roger.
1960 Impala 2dr hard top - 348 tri
Hards..60
Hards..60
Reg: 10-20-07
01-11-18 06:04 AM - Post#2720761
    In response to Hards..60
No one......
Roger.
models916
Loc: Addison, IL
Reg: 05-28-10
01-12-18 05:59 AM - Post#2720840
Not really up on PG but, other transmission I work on would have that part moving freely in a near 0 clearance bore lubed with trans fluid. Might be scored or rusted a little. Try cleaning with scotch bright or steel wool before resorting to emery.
my60belair
my60belair
Loc: Ontario, Canada
Reg: 08-25-14
01-12-18 02:52 PM - Post#2720871
from looking at your pictures and the manual it appears there are 2 pieces not shown in what you removed. The 2 leftmost pieces in the first book picture you show and #8 and #10 in the second manual picture. Those appear to be the ones that have the o-rings. Are they still in the transmission? The part you have out doesn't look like it would have O-rings installed, but I could be mistaken.
Looking at the pictures it does look like you are correct and the spring appears to be in the wrong location, but I'm not a transmission expert.
If at first you don't suceed, destroy all evidence you ever tried...
1960 Bel air Sport Coupe, 1964 Pontiac Catalina Convertible
Edited by my60belair on 01-12-18 02:56 PM. Reason for edit: No reason given.
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
01-12-18 08:39 PM - Post#2720898
    In response to my60belair
There is a first design and 2nd design pressure regulator valve for 1958 8 Cyl. Power Glides.
Also a kit was made to change the first to the seconed design. The first design had too much pressure and broke the reverse band links.
The 1958 material would show the first design but not the seconed design. That would be in a later Service News.
ragtp66
ragtp66
Reg: 12-09-07
01-12-18 11:24 PM - Post#2720909
    In response to Gene_Schneider
[image]https://imgur.com/gallery/piMKg[/image] Pretty sure this is what Gene was referring to 1958 Chevrolet Service News
Toys:
1987 Sea Ray Pachanga 22
Hards..60
Hards..60
Reg: 10-20-07
01-13-18 06:38 AM - Post#2720928
    In response to ragtp66
I agree models916, problem is how do you get that out of the "cage" it's in to clean and inspect without damaging it?
Your right my60belair, parts 6,7,8,and nine are still in there. I'm a little concerned about taking those out, because in the manual it says you have to replace part number 6 if it is removed.
Gene, rag, I paid good money to have this transmission rebuilt. Having said that, I can see obvious mistakes were made. I'm hoping there's nothing else wrong with the transmission other than what I have found. I'm also guessing that something as blatant as a band link would have been caught by the builder.
So, what I'd like to do now is replace those parts listed in the 1960 manual for this reverse kit.
Can I buy this kit from someone so that I may make the repairs.
I would take the transmission to a transmission shop locally but I've tried that and it didn't work. The last place I took it to the tech test drove the car and agreed there was something wrong with reverse. The tech suggested taking the oil pan off first to see if there were metal shavings at the bottom of pan.
I took the car home and you guys now know the rest.
All great responses, guys, much appreciated.
Roger.
Roger.
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
01-13-18 09:48 AM - Post#2720940
If he said anyting about dropping the pan you know he knows nothing about a cast iron Power Glide BECAUSE IT DOES NOT HAVE A PAN.
Yes, they sold a valve body change over kit to update early transmissions. As I recall it contained a plug and necessary to drill a small hole in the plug to reduce pressure. My technical service bulletin #379 says it is part #3759998 and should be installed in transmissions built prior to trans # C-630D.....that is befor June 30, 1958. The installation proceedure is in that bulletin.
Edited by Gene_Schneider on 01-13-18 10:00 AM. Reason for edit: No reason given.
Hards..60
Hards..60
Reg: 10-20-07
01-15-18 06:38 AM - Post#2721086
Gene, as you describe, they have a kit for early 1958, but would they have something for sale today to rebuild or repair the reverse power valve on a power glide like mine....1960.
Thanks.
Roger.
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
01-15-18 03:22 PM - Post#2721117
The case was changed (passage wise) in 1959 and pressure regulator parts were changed accordingly.
Execution time: 0.304 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:43 PM
