Username Post: Wind noise        (Topic#349030)
peejo50
Reg: 03-27-16
01-06-18 07:31 AM - Post#2720207
I have an issue with my 61 Impala 4 door flat top sedan. I have owned this car for 39 years and the issue I’m having is with the wind noise. It’s bothersome generally at 60 MPH and above. I’ve tried new door seals, filling the door jambs with foam tape, and have even gone as far as to tape the complete door and window seams. The noise persists. I have always this problem, but as I get older.... Will I die with this noise issue never solved? Anyone have an answer?
turbo38s10
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
01-06-18 01:32 PM - Post#2720234
    In response to peejo50
Are you sure your kick panel vents are closed all the way?
Sweed62
Sweed62
Loc: NotUS.Language warning#1
Reg: 10-24-04
01-06-18 01:42 PM - Post#2720238
No you are not, you are with CT now.
Jokes aside, welcome peejo50.
I would suspect any antenna or rear mirror for turbulent noise and then try to temporary tape the roof water rail to find the culprit. Volvo had an issue with turbulent noise from an antenna solved by winding a spiral plastic strip around it. Try tapeing one of them at time to find the culprit.
Welcome Svenne
Edited by Sweed62 on 01-06-18 01:44 PM. Reason for edit: No reason given.
peejo50
Reg: 03-27-16
01-07-18 06:31 AM - Post#2720312
    In response to turbo38s10
I've tried with and without vents open. I've also removed the side mirrors and taped over the drip rail from the cowl to the roof. My antenna is in the rear. It sounds like it is right at my ear level. As I have already replaced the window and door seals, and then tried taping over them, I'm at a loss.
Edited by peejo50 on 01-07-18 09:03 AM. Reason for edit: No reason given.
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
01-07-18 12:25 PM - Post#2720350
No one ever accused a 1961 car of being aerodynamic, they were designed to look good. Not sure a wind tunnel existed at GM back then. Just look at the grill and front bumper on these old cars, they had no desire to make them slip through the air.
Member #2194
Jim Streib
Jim Streib
Loc: Saint Louis
Reg: 03-20-03
01-07-18 12:48 PM - Post#2720353
    In response to Sweed62
Man, you gave me a flash back moment. I remember those cars when I was putting aftermarket antenna's on them and had a customer come back with the whistling noise. I didn't believe it until I took it out for a test drive and sure enough, the wrap took care of removing the noise.
1968 Chevy II Nova (Garage Find 2013)
https://www.flickr.com/photos/121766713@N04/ albums...
https://www.youtube.com/user/StlNovas/videos
1973 Nova Custom
1974 Nova Spirit Of America
Jim Streib
Jim Streib
Loc: Saint Louis
Reg: 03-20-03
01-07-18 01:01 PM - Post#2720354
Maybe check to see if there is any service bulletins on your car.
On my 68 Chevy II Nova I started hearing a noise only above 60 MPH but then quit when I went over 70 MPH and had tried opening up and closing the kick panel vents, tried different heater/defrost settings and wondered what was causing it and found that GM put out a service bulletin on a noise created by the grill and a support brace. While I have not tried the fix yet, I do wonder if that is my issue.
1973 Nova Custom
Aussie_Chevy_Nut
Aussie_Chevy_Nut
Loc: Australia
01-07-18 04:23 PM - Post#2720371
    In response to Jim Streib
Hi Guys,
Here in Australia there was a product available at auto parts shops that would be fitted to the grille or some part of the front of the car that would whistle when the car reached a highway speed.
The reasoning behind this was to create a noise that would frighten the Kangaroos and other wildlife that was standing in the middle of the road.
It sounds like a joke I know but I have seen these things in auto parts shops back in the day.
kingkreeton
kingkreeton
Loc: Houston TX
Reg: 04-15-11
01-08-18 10:24 AM - Post#2720438
Bad windshield gasket maybe or loose/damaged trim?
Shane
64 Impala SS: 350 4 speed
"Let's go Reds"
Andy4639
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
01-08-18 01:29 PM - Post#2720464
    In response to Aussie_Chevy_Nut
  • Aussie_Chevy_Nut Said:
Hi Guys,
They where popular here to.
1956 Bel Air - LT-1/4l60
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
turbo38s10
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
01-08-18 01:58 PM - Post#2720466
    In response to Andy4639
Can you better isolate where the noise is coming from? left front , middle , right front etc.
fander
fander
Loc: Hot Springs South Dakota
Reg: 04-28-12
01-09-18 08:52 AM - Post#2720556
Has anyone tried the app on Amazon that monitors sound and noise levels?
brasii
Loc: FRANCE
Reg: 11-09-07
01-13-18 10:42 AM - Post#2720944
Hello ! I had the same problem on my impala 66 convertible , and I found the solution : may be this can help you. If you have the " body fisher manual " for your car , you can see the adjustement for the door window glass : in my case , it was the adjustment " in - or - out " which solved the problem. You need to remove the door trim assembly and inner panel water to expose the adjustment provisions . Look at " body by fisher " service manual , all is in the book ! Good luck !
brokenspoke
Reg: 02-28-08
01-14-18 05:04 AM - Post#2720995
    In response to brasii
I had the same problem once. It was a wistling noise, that I finally found that it was a small screw that was causing the noise. I smeared a very small amount of silly cone on it and it stopped.
Execution time: 0.202 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:22 AM
