Username Post: safe and warm.        (Topic#349013)
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
01-04-18 08:25 PM - Post#2720046
Hi Guys, we have been seeing your cold snap come weather bomb over the news and just hoping you are all keeping safe and well.
Cheers Kiwi
01-05-18 04:44 AM - Post#2720070
    In response to Bel Air kiwi
It must be that dadgum global warming again.
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
01-05-18 04:58 AM - Post#2720071
Hi Robert, I think this is an el nino year where the normal wind systems spin in the opposite direction. Comes around every few years.
Cheers Kiwi
wbeaton
wbeaton
Loc: Hamilton, ON
Reg: 03-07-14
01-05-18 05:19 AM - Post#2720075
Global warming is climate. What we are experiencing is weather. There is a difference. I sure am missing the crazy warm winter we had last year.
1951 Chevy Styleline Deluxe 2 Door Sedan
1954 235 with Isky Cam, Shaved Head
Dual Carter YF 787S Carbs on Offenhauser Intake
Split Manifold Dual Exhaust
3 Speed with 3.55 Differential
12V Conversion with Alternator
Pertronix Ignition
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
01-05-18 05:59 AM - Post#2720082
    In response to wbeaton
Hi Wayne, El Nino is a weather pattern that comes around every few years, El Nina is the normal pattern. I am not even sure if it effects the northern hemisphere very much at all.
When you get a couple of fifty year storms in a row, extra long fire seasons and the beach that used to be across the road lapping at your porch that's global warming.
The problem with global warming is that heat is energy, and raising it makes all weather events more extreme.
Cheers Kiwi
johnwd98
johnwd98
Loc: Little Falls, MN
Reg: 09-05-10
01-05-18 07:27 AM - Post#2720091
Whenever it gets this cold, we start seeing videos on the news of people throwing a glass of hot water in the air and it turns to vapor before hitting the ground. Or blowing soap bubbles and watching them freeze. Or it's too cold to snow. The local news seemed to have turned to bragging about who had the coldest wind chill temperature. Nothing to be proud of as far as I'm concerned, Haha.
tommy49
tommy49
Loc: Kaleva, Michigan
Reg: 09-28-12
01-05-18 07:47 AM - Post#2720096
    In response to johnwd98
It's currently -1 here and 55 in the shop. It's been snowing about 5" every day and we're only doing full snow blowing every 4-5 days. The tractor uses about 4 gallons of gas every full snow blow and it take us about 3 hours to do a complete clean up. The walks to the shop and firewood are the only daily shoveling we do.
Tommy
49 Deluxe Sport Coupe, 55 235, 700r4, Blazer rear axle, 4 wheel power disc brakes.
VANDENPLAS
VANDENPLAS
Loc: ontario canada
Reg: 07-29-09
01-05-18 07:52 AM - Post#2720097
    In response to tommy49
Minus 40 celcius here !!!
I’m working out side !!!
Idiotic customer has a diesel Forklift outside the last 4 days not plugged
Got 4 propane heaters on it now with a 24 volt booster trying to get it going
5 minutes outside 20 minutes in my truck trying to get warm
Had to go buy either as the can I had froze in the back of my van
It’s PAINFULL COLD today. !
In the land of the blind the one eyed man is king πŸ‘‘
01-05-18 07:52 AM - Post#2720098
18 below in upstate NY, just left, now in the Fla panhandle, 30 degrees!! I was very careful blowing down my water system as I don't leave the heat on.
dsacton
dsacton
Loc: Boulder, CO
Reg: 11-01-11
01-05-18 11:42 AM - Post#2720121
Boulder, Colorado decided to sit this one out. 57 degrees F yesterday, and I went for a bike ride.
I should add that my wife reports a $5/day extra on the electric bill to keep my garage warm (where the '54 is). Sure wish I had a gas heater...
Scott Acton
1954 Chevy Bel Air 2-door
http://www.my54chevy.com
VANDENPLAS
VANDENPLAS
Loc: ontario canada
Reg: 07-29-09
01-05-18 01:04 PM - Post#2720131
    In response to dsacton
GOT IT GOING!!!!!!
1/2 can of either and a propain torch on the intake and fuel lines and she came to life like Satan himself breaking down the gates of hell !!! Screaming clanking smoking wow!!!!!!
Know what I did is not by the books but it was either get this thing running or let the cylinder head blow off the block and land in their neighbors yard!!!
Truck is a 95,000 lbs capacity Taylor Forklift, give it a funky paint job and it would fit in perfectly in a mad max movie !!!!
tommy49
tommy49
Reg: 09-28-12
01-05-18 01:37 PM - Post#2720137
Weather patterns are affected by that dadgum global warming. I think it's called science.
Tommy
01-05-18 09:42 PM - Post#2720181
Attaboy Vandenplas! We knew you had it in ya. When all else fails break out the propane torches and the ether... just don't mix them.
Cruzin Okie
Cruzin Okie
Loc: Jay, Oklahoma
Reg: 10-26-11
01-06-18 03:54 PM - Post#2720264
Wasn't that one of the presidential promises, to fix global warming, or something like that? I guess it could be that wall down south keeping the warm out.
Johnnie
1950 styleline deluxe sports coupe, 350 cid, TH 400, nova rear end. Gen IV Vintage air. SOLD!
1953 210 4 Door, 235 with Powerglide. All original except for the 1954 hood bird.
John 3:16
Edited by Cruzin Okie on 01-06-18 03:55 PM. Reason for edit: No reason given.
4dr 57
4dr 57
Loc: Texas Hill Country
Reg: 11-10-04
01-12-18 08:48 AM - Post#2720856
Yeppers, it's colder here than it has been the last couple of years also...makes me want to move to San Antonio Every time I think of global warming especially in winter, I think of some part of the Northern part of the planet with it's azz hung out exposed to space that's chilling it all and the only thing happening is the weather winds pushing all that cold around the planet! Brr.
It's all good. mostly
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
01-13-18 03:27 PM - Post#2720966
    In response to Cruzin Okie
Hi Pastor Johnnie, Are you manipulating the excrement there?
Apparently there has been a flip flop on that too.
Paris Climate accord may be back on for you guys, so all good.
Apparently an El Nino give you more tornado's.
Personally I hate seeing good folk anywhere loose everything through fire flood, drought, mudslide or whatever.
Cheers Kiwi
Execution time: 0.202 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:23 AM
