Username Post: 54 3100 defroster        (Topic#349000)
ledzepn
Loc: Washington
Reg: 03-17-17
01-03-18 07:04 PM - Post#2719930
Why is it that when I turn on the defroster, my windshield frost up badly for a long time? I have to keep wiping the windshield off with a towel. I do better not even using the defroster at all.
bobschevytrucks.com Ecklers Chevy Trucks LMC Trucks
01-04-18 01:18 AM - Post#2719945
    In response to ledzepn
Possible heater core leak. Do you smell antifreeze inside the cab or are you noticing any coolant loss?
ledzepn
Loc: Washington
Reg: 03-17-17
01-04-18 11:57 AM - Post#2719997
No leaks that I can see or smell.
Mick53
Platinum Supporting Member
Mick53
Loc: Northern Indiana
Reg: 04-02-16
01-05-18 06:43 AM - Post#2720087
Have you tried not breathing or cracking a window?
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
01-09-18 06:33 PM - Post#2720618
    In response to Mick53
Hi Ledzepen, because its an old cast iron engine that takes at least 5 minutes to get warm enough to heat the coolant up to anything like a useful temperature to effect the internal condensation by way of the defroster.
Also if your thermostat has failed open then this will take longer still. Also your heater core could be a bit clogged up and may not be working effectively. I have come across them being blocked solid in a different car.
You can often clear them in place by using a low pressure garden hose to flush them. But whatever you do do not use air pressure. The core will burst.
I just gently run the garden hose in each disconnected end of the heater hoses at the front of the car. Do this on the lawn not the drive. Patience is the byword here. As the original core is for about a 4-6 Psi system if you want to run more pressure in the radiator then you need to upgrade the heater core to match.
The other issue is that the heater water valves often seize and what is moving is just the cable. You need to use them regularly to avoid this, more than just seasonal.
Plan "B" is Aircon. Which dehumidifies, not heats, so can work with cold engines in about 30 seconds.
Hope this helps, cheers Kiwi
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
01-10-18 03:26 PM - Post#2720710
    In response to Bel Air kiwi
You have water or coolant in the heater case and it is evaporating. This is NOT a "normal" problem and should not happen.
Do you have the cheap recirculating heater or Deluxe Air Flow heater?
ledzepn
Loc: Washington
Reg: 03-17-17
01-12-18 11:20 AM - Post#2720866
    In response to Gene_Schneider
I don’t know what brand it is. How do I find out?
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
01-12-18 07:44 PM - Post#2720899
The fresh air heater is larger and mounts on the side because it takes in air from the louvers on the side of the cowl.
The little heater mounts to the fire wall
Execution time: 0.256 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:54 AM
