Username Post: Setting valves        (Topic#348979)
Gaspains
Gaspains
Loc: Mankato, MN
Reg: 11-23-09
01-02-18 05:29 PM - Post#2719815
I've always had the engine running any time I set valves in the past. It can be messy! I hate to get oil all over a fresh restoration. It didn't matter so much in the past.
Has anyone set intake and exhaust with the engine stopped, rotating the crank and adjusting in sequence?
If so, how did it work out? Any pointers?
Kevin
1965 Impala SS Coupe
Regal Red with Black Interior
L74 327
M-20
3.31 One-wheel wonder, 12 bolt
65-66 FSCC #512
space66
space66
Loc: montreal
Reg: 06-01-16
01-02-18 06:17 PM - Post#2719822
    In response to Gaspains
usually do it on a fresh start-up ,some times it works and some times it doesn't, depends how used the parts are. (1/2,3/4,1 turn) so final tweak will be running. you can get old valve covers and cut an opening ,not as messy.
here's some good info on it,no spinning, up/down
http://berlinetta.info/Lash.htm
1966 impala convertible 283*pg-396*th350
models916
Loc: Addison, IL
Reg: 05-28-10
01-03-18 05:49 AM - Post#2719857
    In response to space66
If you are talking hydraulic. It won't make any difference. On a solid, run it hot, turn it off and set the #1 intake and exhaust and let it cool over night. Remeasure both set valves and repeat those numbers on the other 7 cylinders cold.
jktucker92
jktucker92
Reg: 02-05-17
01-03-18 08:21 AM - Post#2719866
    In response to models916
I've done it both ways. They make deflectors that will make it less messy, but you still end up with some oil dripping down the side of the heads. With hydraulic lifters, I've always had good luck doing it with the engine on the engine stand at the end of a rebuild. As mentioned above, with hydraulic lifters the valve lash setting doesn't have to be very precise since the lifter will take care of a lot. The link above is the procedure I've used in the past and I can't remember having to redo valves after setting them cold on the engine stand, and I've probably done it 40 times over the years on a small block for either rebuilds or head replacement.
Gaspains
Gaspains
Loc: Mankato, MN
Reg: 11-23-09
01-04-18 05:54 AM - Post#2719949
Great link. Thanks for the info all.
I used to have a valve cover that I'd cut in half to contain the oil. Haven't seen it in years and not willing to cut another one up so the non-running procedure looks like the real deal.
Assuming I can pump up the hydraulics (should have mentioned in my first post the type) with a drill and adapter. I'd like to do the first start with lifters adjusted.
Again, thanks.
Kevin
L74 327
M-20
65-66 FSCC #512
space66
space66
Loc: montreal
Reg: 06-01-16
02-02-18 08:23 AM - Post#2723064
this is an interesting method i never knew, something to try the next time...
*Hydraulic valve adjustment made easy - Your Engine Guy
https://www.youtube.com/watch?v=5EGlb_VpTAw
any body familiar with it?
jktucker92
jktucker92
Reg: 02-05-17
02-02-18 11:21 AM - Post#2723088
Yes, that's the method I was taught in high school. It has always worked well for me, I've never had to re-adjust hydraulic lifters after initial startup using that method. I've rebuilt about 10 SBC's in the last 25 years, and never had an issue.
Gaspains
Gaspains
Loc: Mankato, MN
Reg: 11-23-09
02-03-18 06:38 AM - Post#2723176
    In response to jktucker92
Excellent! I’m glad I hadn’t started this yet. It makes perfect sense to me.
The only thing that I may have to do different is spinning the push rod between the head and rocker arm rather than in the lifter galley as I have the intake on. I think it’s also important to prevent the socket from contacting the ball when adjusting to zero lash.
Thanks for sharing the link.
Kevin
L74 327
M-20
65-66 FSCC #512
Execution time: 0.285 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:59 PM
