Username Post: Battery in trunk question        (Topic#348974)
apix17
Loc: San Francisco Area
Reg: 12-22-07
01-02-18 01:40 PM - Post#2719789
I am going to relocate my battery to the trunk. My question is has anyone attempted to route the positive cable through the inside of the chassis. It looks like maybe I could enter it in the rear near the bumper mount and exit in the front near the control arm.I would wrap the 2awg cable with spiral wrap and fuse the battery also. Any comments appreciated. This is on a 55 Belair 2 drhdt Thanks.
Edited by apix17 on 01-02-18 01:54 PM. Reason for edit: No reason given.
01-02-18 01:48 PM - Post#2719791
    In response to apix17
Notice the brass ground connection brazed to the top of the frame. There's another in the back near the battery.
Edited by acardon on 01-02-18 01:50 PM. Reason for edit: No reason given.
BobbyW
BobbyW
Reg: 11-20-08
01-02-18 03:08 PM - Post#2719797
    In response to acardon
We did mine that way and had starting problems for ever. Tried several different starters to no avail. Finally a gentleman told me to add a Ford solenoid switch and it would resolve the problem.
We did that and have not had anymore starting problems.
"If you don't know me,
You have missed little.
If you don't know my best friend,
You have missed it all."
01-02-18 05:05 PM - Post#2719810
Be aware that a "2 piece" frame has bulkheads inside the frame rail that will make routing the cable through there difficult, but it can be done. The bulkheads block most of the inside of the frame, only the corners have a possible route for the cable. I don't think a "1 piece" or seamless frame has those, but not sure what it has.
Jim Streib
Jim Streib
Loc: Saint Louis
Reg: 03-20-03
01-02-18 06:04 PM - Post#2719819
While I have not attempted running a power cable inside a frame like yours, I would do what you can to look inside to see if anything could rub against it or if there are any wire feed straggler wires that might poke through the wires insulation. If there is room.maybe think about adding another layer of insulation around the wire inside the frame. On my 73 Nova Custom I have Monster Cable 1/0 wire off of the starter and alternator and had some old true braided steel heater hoses laying around that the wire fit into and now the wire is covered and looks better and has a thicker and more heavier protection. I have also done the same thing with regular heater hose in area's for added protection.
Speaking of wire, make sure the gauge wire you have is large enough for the amperage demands AND make sure it's copper stranded wire and not the inferior copper clad aluminum type which some companies refer to as CCA wire.
A neat bushing I have used for passing the cables through metal are these:
1/0 Waterproof Locking Cable Bushing
One last thing is put the battery inside of a sealed enclosure and have it vented to the exterior of the car and have the case as well as the battery secured well to keep in it place in the event of an accident.
1968 Chevy II Nova (Garage Find 2013)
https://www.flickr.com/photos/121766713@N04/ albums...
https://www.youtube.com/user/StlNovas/videos
1973 Nova Custom
1974 Nova Spirit Of America
Execution time: 0.174 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:17 AM
