Username Post: So many plugs        (Topic#348967)
Am4wag
Reg: 11-19-15
01-01-18 08:48 PM - Post#2719737
Putting together 30 over Gen.VI 454 with Bowtie aluminum heads,very similar to the ZZ454 crate engine except I'm running a point more compression (10.2) and a bit more cam (https://www.crower.com/camshafts/chevy-396-4 54-hydraulic-roller-cam-2 22hr229-late-model.html).Looking at plugs,the AC #4 is mentioned for the ZZ454,so I'm looking at this chart:http://www.sparkplug-crossreference.com/convert/AC_DELCO/4 and wow,the choices.I need plugs to put in this engine with these heads that I can buy locally.Which ones to start with?BTW,no power adders and pump gas only.
The bearer of gossip is a small untrustworthy person who takes delight in someone else's problems. Avoid them.
Let's all make the day count. - Charlie Daniels
Execution time: 0.631 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:23 AM
