Username Post: bbc ring gap        (Topic#348945)
Am4wag
Reg: 11-19-15
12-31-17 06:24 PM - Post#2719581
Just want a final word before I sink the pistons.I file fit the rings as follows-Top rings at .020",2 went to .022".2nd.rings at .018",1 went to .020".These are the rings I have:
http://www.libertyperformance.com/pdf/FILE_FOR_RIN...
Ofcourse,the gap specs. for these rings go against all other gap recomendations I've been reading,where they state same for the top ring (.0045" X bore),but state .0055" (wider) for the 2nd.ring.
The bearer of gossip is a small untrustworthy person who takes delight in someone else's problems. Avoid them.
Let's all make the day count. - Charlie Daniels
12-31-17 06:32 PM - Post#2719584
    In response to Am4wag
Naturally aspirated, no nitrous? If so your clearances sound ok, of course ring spacing is important.
Edited by Shepherd on 12-31-17 06:37 PM. Reason for edit: No reason given.
12-31-17 07:34 PM - Post#2719597
The clearances in your link are a bit big for a stock piston or an aftermarket forged piston. But not much. For those .004"/inch of bore is the general rule of thumb.
But, and this is a huge but, if you have hypereutectic cast pistons you may need more gap, and you should follow the manufacturer's recommendations.
So all this depends on your pistons, not your rings.
Am4wag
Reg: 11-19-15
01-01-18 10:13 AM - Post#2719658
    In response to Rick_L
Sorry I failed specifics....30 over 454 Race Tech forged pistons 10.2 comp.
Execution time: 0.141 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:09 PM
