LMC Truck
Username Post: Adding cold oil at 11F        (Topic#348892)
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
12-28-17 03:12 PM - Post#2719242
Today I was adding a quart of 5w30 to my 454. The Vortec 454 uses a vertical-ish tube that goes into the intake manifold like some of the early small blocks...at 11F the oil is thick enough that the tube fills up because the oil doesn't flow fast enough to get out of it's own way!
99 K3500 RCLB
LMC Trucks
TAT_2
"17th Year" Silver Supporting Member, and Official CT Grim Reaper
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
12-28-17 04:16 PM - Post#2719258
    In response to 454cid
I MOVED MY OIL INTO THE HOUSE FOR WINTER.IM ANUAL THAT WAY. ITS IN THE SPARE BED ROOM.I ALSO STARTED STOREING MY EXTRA OIL IN GLASS JARS,THE PLASTIC CONTAINERS SWEAT INSIDE & FORMS WATER IN THE OIL. HAD SOME EXTRA GTX DO THAT.
09 PONTIAC- VIBE
08 PONTIAC- G6
96 FURD F-150 SUPER CAB XLT 4X4
NEXT ?
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
12-28-17 06:51 PM - Post#2719277
    In response to TAT_2
  • TAT_2 Said:
....I ALSO STARTED STOREING MY EXTRA OIL IN GLASS JARS,THE PLASTIC CONTAINERS SWEAT INSIDE & FORMS WATER IN THE OIL. HAD SOME EXTRA GTX DO THAT.
That's what the PCV system is for!
99 K3500 RCLB
TAT_2
TAT_2
Reg: 10-29-00
12-29-17 03:48 PM - Post#2719365
THE VIBE ONLY USES 4.5 ON A OIL CHANGE,SO I ALWAYS HAD .5 QT LEFT OVER.I WOULD LEAVE THE X-TRA IN THE QT "PLASTIC" CONTAINERS.WITH THE VARYING TEMP CHANGES APPARENTLY IT FORMED MOISTURE INSIDE THE CONTAINER.THE X-TRA OIL WAS STORED OUTSIDE.I POURED THE CONTAMINATED OIL IN A GLASS JAR & LET IT SIT FOR A FEW DAYS,THE WATER SETTLED TO THE BOTTOM.I CHANGE MY OWN OIL & DO IT WHEN ITS HOT,I LET THE MOTOR COOL DOWN B4 I POUR THE NEW OIL IN.SURE I'VE SEEN GRAY CONDENSATION ON THE DIP STICK ALSO,BUT THATS BEEN A LONG TIME BACK.
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
LMC Trucks
Execution time: 8.412 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:44 AM
