Username Post: Recondition rocker arm assembly’s        (Topic#348889)
Sethmark
Loc: Statesboro, GA
Reg: 05-04-16
12-28-17 12:00 PM - Post#2719217
Looking for someone to either source or recondition set of 1959 rocker arm assembly’s for me. Anyone have experience or parts available?
Sethmark
Loc: Statesboro, GA
Reg: 05-04-16
12-28-17 02:43 PM - Post#2719227
    In response to Sethmark
Never mind. Sourced.
tommy49
tommy49
Loc: Kaleva, Michigan
Reg: 09-28-12
12-28-17 02:57 PM - Post#2719231
Who? Where? Link?
Tommy
49 Deluxe Sport Coupe, 55 235, 700r4, Blazer rear axle, 4 wheel power disc brakes.
Sethmark
Loc: Statesboro, GA
Reg: 05-04-16
12-28-17 07:29 PM - Post#2719275
    In response to tommy49
Jjinlines. Rocker arms unlimited can do them too.
tommy49
tommy49
Reg: 09-28-12
12-29-17 05:35 AM - Post#2719296
Thank you!
Tommy
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
12-30-17 02:37 AM - Post#2719399
Hi Guys, not 100% on the exact detail but I thought 59 on engines had quite different rockers and shaft that had a unique oil supply system up to the rockers and also inside the rockers themselves.
It might be worth having a look on the online site.
Cheers Kiwi
tommy49
tommy49
Reg: 09-28-12
12-30-17 07:08 AM - Post#2719414
    In response to Bel Air kiwi
Cheers Kiwi
For what it's worth, I'm using 62 235 rockers, shafts, and oil tube on my 55 235.
Tommy
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
12-30-17 07:16 AM - Post#2719415
The only difference was the groove inside the bore of the rocker shaft it was moved to the center in line with the oil hole on the top of the rocker. The geometry did not change.
I can rebuild the rocker assy's here and keep shafts for my own use and recondition the rocker arms also.
12-30-17 10:39 AM - Post#2719426
Hi Guys, not 100% on the exact detail but I thought 59 on engines had quite different rockers and shaft that had a unique oil supply system up to the rockers and also inside the rockers themselves.....
Kiwi, you are absolutely correct about the rocker arm oiling system. The change is described in detail here:
http://chevy.oldcarmanualproject.com/shop/1959_60/...
According to the parts book, the 59-up rocker arms are also different from 58-earlier, but I don't know what the specific difference is.
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
12-30-17 11:14 AM - Post#2719430
The shafts are the same, the difference is the oil grove is off set from 1959-1962 because there was higher oil pressure up to the arms and this was a restriction. If the off set grove arms are used in a 1955 engine the oiling will be very restricted becuse the oil grove will not be in line with the oil hole in the shaft.
12-30-17 11:23 AM - Post#2719434
    In response to Gene_Schneider
Thank you, Gene. That makes perfectly good sense.
Sethmark
Loc: Statesboro, GA
Reg: 05-04-16
12-30-17 11:43 AM - Post#2719436
Man, you guys are a wealth of information. I appreciate all the help. I did purchase reconditioned rockers that were specifically for the 58 to 62 motor. Thanks again.
kensluys
kensluys
Loc: Bellingham, WA, USA
Reg: 04-18-01
01-02-18 11:30 AM - Post#2719781
Not to overkill the subject, but here's more information from Dave Folsom:
http://chev235guy.blogspot.com/search/label/235%20...
1951 Bel Air - January build date.
Execution time: 0.265 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:08 PM
