LMC Truck
Username Post: Fog lights on all the time with driving low beams        (Topic#348830)
YOUNG57
Loc: Tennessee
Reg: 12-06-10
12-23-17 10:10 AM - Post#2718852
Has anyone changed the wiring so their fog lights come on every time with their headlight low beam do. Of course my headlight low beams come on as driving/running lights anytime it is in drive.
Would there be any negative reason not to do this?
LMC Trucks
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
12-24-17 04:40 PM - Post#2718947
    In response to YOUNG57
I’m surprised they even come on at all on high beam. Isn’t factory setting off with high beam and on with low? Both my ‘00 Contour and Explorer had/have fogs that we’re off with high beam.
Granted, they’re not GM, but it makes sense that the low beams would have the fogs enabled for safety. High beams scatter terribly in snow and fog.
Greg
'00 Explorer XLT 4.0 V6 Auto
Miami Son
Loc: God's waiting room
Reg: 08-03-17
12-26-17 05:47 AM - Post#2719022
    In response to CowboyTrukr
He didn't say anything about high beams. He wants the fog lamps to come on automatically when his low beams are on instead of always having to remember to turn them on manually. I wouldn't mind that, either.
12-26-17 11:53 AM - Post#2719039
Possibility of exceeding the headlight breaker rating if you directly connect the fog lights to the low beam circuit. One way to get around this would be to retain the existing fog light power feed and use a relay to do the switching.
YOUNG57
Loc: Tennessee
Reg: 12-06-10
12-28-17 08:33 AM - Post#2719205
Like Miami Son said I just want the fog lights to come on automatically every time I drive. I just want to trigger the fog light relay when in drive. Maybe a jumper at the fog light dash switch? Just wondering if anyone has done something similar.
In the fuse panel under the hood there are relays for each of the high, low and fog lights so circuit overloading isn’t an issue.
YOUNG57
Loc: Tennessee
Reg: 12-06-10
12-30-17 06:30 PM - Post#2719476
Since no one seems to have figured out how to get the fog lights to come on automatically has anyone figured out how to keep the low beams on with the high beams?
12-30-17 11:04 PM - Post#2719496
I told you how in general terms in my previous post. If you want the hookup spelled out, run a jumper from the fog light relay coil terminal to the low beam relay load terminal. This will turn on the fog lights whenever the low beams are lit, but still allow you to operate the fog lights independently from their own switch without the low beams being on.
If that's not how you want them to work, please state your requirements in more detail.
YOUNG57
Loc: Tennessee
Reg: 12-06-10
12-31-17 09:53 PM - Post#2719613
Sorry Ray, I didn’t understand your post until you explained it better, thank you. That’s what I wanted to know.
Run a jumper wire from 87 terminal on HDLP LO/HID relay to the 86 terminal on the FOG LAMP relay.
Edited by YOUNG57 on 01-01-18 07:51 AM. Reason for edit: No reason given.
01-01-18 08:36 AM - Post#2719646
Yes, that sounds good.
LMC Trucks
Execution time: 0.479 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:36 PM
