Username Post: Oil pressure sensor        (Topic#348825)
Jeffrey0180
Loc: The Netherlands
Reg: 12-22-17
12-23-17 07:51 AM - Post#2718838
Hey everyone,
I want to remove the 90 degree elbow that sits in the block, do i need to remove the distributor to remove it? Its a 1994 TBI 350. And will removing the distributor cause any timing problems?
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
12-23-17 09:41 AM - Post#2718846
    In response to Jeffrey0180
It’s a bit easier to do it with the distributor out because you can see it better. Try it with just the cap off. That way you won’t be messing with the timing.
Simply removing and replacing the distributor won’t cause problems so long as you stab it back in place correctly and reset the timing properly as per spec. Do you have a standard timing light?
I’ve done R&R on a distributor without problems many times. The key is to mark your reference points very well with some masking tape and a Sharpie. Label all your plug wires, lay down a solid #1 cylinder reference, mark the cap, the housing under the cap, and the exact position of the rotor under the cap before you loosen the clamp bolt. You’ll find it a bit easier if you already have the rotor lined up with wire #1. (Timing mark already set at 0). The key to remember is that the rotor is going to need to rotatate a few degrees counter clockwise as you lift it from the manifold. Don’t forget to mark that second position on the housing. It will make resetting things a lot easier.
Don’t forget to pull the tan/Black timing advance connector open to set your base timing again.
Be very careful to not put any horizontal stress on the vertical while you are removing the pressure switch.
If you don’t mind me asking, where are you putting the pressure switch after you remove the 90?
Greg
'00 Explorer XLT 4.0 V6 Auto
Jeffrey0180
Reg: 12-22-17
12-23-17 12:15 PM - Post#2718856
    In response to CowboyTrukr
I am removing the 90 because i suspect an oil leak coming from it, i am also gonna replace the paper gasket beneat the distributor since its really wet around there to, i am gonna put the 90 back with some sealant.
I do not own a timing light, nor have i ever done the timing on the igniton, but if i mark everthing correctly i wont have to many problems with the timing? As long as it starts and runs i can take it to a shop.
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
12-23-17 03:09 PM - Post#2718871
You can probably get the timing close. Getting it within 10° by marks will be close to impossible. Spend $40 on a timing light. That's probably close to what someone will charge you to time it and you'll be able to do it yourself next time.
Jeff
Execution time: 0.281 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:55 PM
