Username Post: 350 TBI Distributor Leak        (Topic#348813)
Jeffrey0180
Loc: The Netherlands
Reg: 12-22-17
12-22-17 02:12 AM - Post#2718739
Hey everyone,
I have a 350 TBI in my 1994 C1500, i have a pretty big oil leak on top of my intake manifold below the distributor, im guessing either the OPS is bad or the distributor O-ring/Gasket. My question is, does the distributor on this engine have a gasket between the Manifold and the Distributor, or does it only have an o-ring in the distributor??
Regards,
Jeffrey
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
12-22-17 06:14 AM - Post#2718747
    In response to Jeffrey0180
More than likely the intake needs to be resealed. The front and rear of it is sealed with black RVT.
Jeffrey0180
Reg: 12-22-17
12-22-17 06:34 AM - Post#2718751
    In response to junkman104
Can it be the intake gasket if there is oil on top of the manifold, around the dizzy? The entire shaft of the dizzy is soaked with oil, i was also thinking maybe the brass elbow fitting from the OPS. But if it is the intake gasket, will there be oil on top of the manifold??
rain_man_rich
Loc: Grants Pass, OR
Reg: 02-09-14
12-22-17 11:23 AM - Post#2718778
I replaced my distributor a couple of years ago. I'm almost positive there was a paper gasket that fit between the distributor flange and a the counter sunk machined surface on the intake. In addition to the intake seal to the block as mentioned above, there's also an oil pressure sending unit back there. It could be that this unit is leaking oil and dropping onto the intake manifold. Normally they "hang" in a position that this couldn't happen but perhaps the pipe has been twisted in such a way that it hangs over the intake manifold. It's a long shot but maybe. I'd clean it all up and put some dye in the oil and with an ultraviolet light and glasses find the leak. Napa has a kit for around 20 bucks.
Jeffrey0180
Reg: 12-22-17
12-22-17 12:32 PM - Post#2718788
    In response to rain_man_rich
I already checked the ook pressure sensor and iT isnt leaking, Gonna start removing the throttle body and distributor this sunday and remove the manifold, this is nu fitst time doping this job, Antonie tot tips or things to look out for?
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
12-24-17 04:01 PM - Post#2718940
there is a gasket between the distributor and the manifold. absolutely necessary to prevent a leak
56 bel air ((since 2002)
62 impala ss (since 1965)
65 el camino (since 1969)
66 nova (since 1987)
83 gmc 4wd (since 1991)
95 impala (new)
14 camaro (new)
Execution time: 0.255 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:10 PM
