Username Post: One injector pulse        (Topic#348809)
Bigswole 1999
Reg: 12-21-17
12-21-17 07:34 PM - Post#2718726
I have a 95 gmc k1500 the truck was running fine i put a dash in it and the hvac box out of another truck in it during the process i had to unplug the computer and once i put everything back together the the truck ran like crap so i started looking and only one injector was fireing so i read on another form that d14 and d16 in the ecm plug were the injector drivers so i checked the plug and all of the wires were fine but d 16 pin in the was bent so i straightend it back out and still no luck any help would be greatly appreciated
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
12-22-17 06:24 PM - Post#2718815
    In response to Bigswole 1999
Have you checked yor ECM fuses under the hood?
Greg
'00 Explorer XLT 4.0 V6 Auto
rockfangd
Loc: Utica ny
Reg: 04-13-10
12-22-17 08:12 PM - Post#2718822
    In response to CowboyTrukr
You are on the right track with that pin.
Check for pulse output from that wire while running. Should pulse a negative every time it goes to fire the injector.
Likely you have a bad connection there,
How bad was the pin bent (in the ecm I assume)
Old School GM fan FOREVER
Execution time: 0.184 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:27 AM
