Username Post: 4l80e not shifting properly        (Topic#348801)
wkobe
Reg: 02-04-04
12-21-17 12:25 PM - Post#2718674
Ok i swapped 4l80e into my truck from a truck with a bad frame that sat for about 3 years and was fine prior to sitting. changed the filter and fluid dropping the pan not a complete flush and fill. when i get on it to downshift sometimes it doesnt want to shift back to OD. is there anything i can do for this short of a rebuild? any additives? 98 k2500
wayne
1996 k1500 4.3 276k miles
1996 k2500 5.7 118k miles
1998 k2500 5.7 115k miles
Edited by wkobe on 12-21-17 12:28 PM. Reason for edit: No reason given.
stumppuller
stumppuller
Loc: Canada
Reg: 11-01-04
12-21-17 05:52 PM - Post#2718711
    In response to wkobe
So does everything else in the transmission work normally, with the exception of loosing overdrive after a forced downshift?
-91 Sierra C2500, now K2500
-81 Chev K20
wkobe
Reg: 02-04-04
12-21-17 07:22 PM - Post#2718721
    In response to stumppuller
as far as i can tell all else is good from my first drive of about 10 miles.
wayne
stumppuller
stumppuller
Loc: Canada
Reg: 11-01-04
12-22-17 09:48 PM - Post#2718825
I would drive it a little more before condemning the transmission.
- See if it is a hot vs cold issue.
- Also, when OD is no longer available, check carefully to see if all 3 other gears and the TCC (Torque Converter Clutch) are working properly.
- Make sure the check engine light is not on, and there are no codes stored for the transmission
-81 Chev K20
wkobe
Reg: 02-04-04
12-23-17 07:12 PM - Post#2718894
Ok may have found an issue fluid level was about 2quarts low. It's not easy checking fluid after pouring fluid in you get 'false' readings and thought it's was about a 1/2 quarts high but no so I will test drive tomorrow and see how it does
wayne
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
12-24-17 04:49 AM - Post#2718911
let us know the testing result please
wkobe
Reg: 02-04-04
12-24-17 02:48 PM - Post#2718933
    In response to grumpyvette
it isnt any better and it shifts kind of hard i think i need to get a tank of fuel thru it to give things time to free up from sitting if it gets better i will get let you all know.
wayne
Edited by wkobe on 12-24-17 02:51 PM. Reason for edit: No reason given.
wkobe
Reg: 02-04-04
01-07-18 06:28 PM - Post#2720380
well truck was dropped off at a reputable shop getting transmission rebuilt done fighting with it. Mike smith transmission danielson ct
wayne
wkobe
Reg: 02-04-04
01-17-18 06:13 PM - Post#2721327
well truck is back shifts as it should other than im not sure when it should go into od right now seems to only go into od above 60 does this seam right
wayne
Execution time: 0.171 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:45 AM
