Username Post: EFI Throttle body 350 Chevy        (Topic#348767)
SteveW
Loc: Shreveport
Reg: 04-24-02
12-19-17 07:00 AM - Post#2718410
Can someone who has one tell me about the MSD Atomic EFI Throttle Body Systems 2900.
1. How hard is it to hook up on 350 chevy?
2. Do I need to get a gas tank with a pump inside?
3. Any information about what I need to buy would be great. Thank you. Steve
SteveW
12-19-17 07:28 AM - Post#2718413
    In response to SteveW
It comes with a fuel pump. Link to EFI kit. .... Watch the video. You will need a bung in the exhaust collector for the O2 sensor.
You might get more responses in the "EFI/Fuel Injection" section.
Edited by acardon on 12-19-17 08:01 AM. Reason for edit: No reason given.
Andy4639
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
12-19-17 08:44 AM - Post#2718424
I've been running fuel injection in my 71 c 10 since early 90's. Although I ran a TPI unit I wouldn't do a EFI system without a tank pump unless you go with the new pump and tank under the hood. Like in the picture. But be warned they are expensive. Moding a tank sendor to use is much easier in my opinion.
1956 Bel Air - LT-1/4l60
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Bruces 57
Reg: 01-03-07
12-19-17 09:07 AM - Post#2718429
    In response to Andy4639
Hello;
From what I know, using the above pictured Fuel Command Center (in theory) is easier because you use your existing mechanical fuel pump to feed that command center and that makes the pressure necessary to feed a throttle body!
FI Tech is one of the game players making FI more affordable and easier to install!!
Bruce
Andy4639
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
12-19-17 04:14 PM - Post#2718463
    In response to Bruces 57
The biggest thing I see about using this is if you have a wreck you have a good chance of fuel being all over the engine.
I have modded several C10 sendors for guys to run EFI in their trucks with no problems.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Bruces 57
Reg: 01-03-07
12-20-17 07:13 AM - Post#2718541
Hello;
Well, from what I see the command center can be mounted anywhere there is 12V to operate it! You just have to run longer fuel lines to and from.
I had a plan to install this in my 32 Hot Rod but absolutely no room in the engine compartment!!! So because I moved my battery to the rear of my car that left a stainless insulated battery box under the passengers seat under the car! I didn't take any measurements yet!!
but Im thinking it will fit quite nicely there!!!
Bruce
Henrys57wagon
Canadian Regional Coordinator &"12th Year" Silver Supporting Member
Henrys57wagon
Loc: Carleton Place ON, Canada
Reg: 04-15-06
12-31-17 06:20 AM - Post#2719513
I have been running EFI in the 57 for years. I used an external pump mounted on the rear frame and a return line back into the filler pipe. Never any issues with fuel starvation. Check out some pic's on the fuel and air tab on my picturetrail site from link below. good day
57 B/A wagon, 408"BB with 14' Bonair travel trailer,71 Nova 355"SB, 07 2500HD with 26 Prowler 5th wheel, 09 Impala LT, John Deere lawn tractor,
http://www.picturetrail.com/sfx/album/listing/use r...
4dr 57
4dr 57
Loc: Texas Hill Country
Reg: 11-10-04
01-12-18 02:39 PM - Post#2720877
    In response to Henrys57wagon
I have been running a factory s.f.i. system with an external pump, return line to the fill pipe, also retained the carbon canister, for years with no problems.
Stanely
It's all good. mostly
Execution time: 0.285 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:03 PM
