Username Post: 1994 Chevy c1500 5.7 backfire issue        (Topic#348749)
Caleb94chevy
Reg: 12-17-17
12-17-17 07:48 PM - Post#2718306
Hey all would Appericate any help. I’ve got a 1994 5.7 tbi c1500 that backfires when warm with more than half throttle applied. I don’t know how to fix I’ve changed spark plugs and wires cap and rotor ain’t very old new temp sensors and ignition coil and tps. Thanks for any help.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
12-17-17 08:22 PM - Post#2718309
    In response to Caleb94chevy
I would be checking the timing. If the timing is off that would cause a backfire as the cylinders are not firing at the right time.
There should be a FAQ on it.
Also check your injectors. See if they are misting properly or if they are dribbling
Welcome to ChevyTalk
Old School GM fan FOREVER
Edited by rockfangd on 12-17-17 08:24 PM. Reason for edit: No reason given.
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
12-18-17 05:31 AM - Post#2718335
It could also be a flat cam lobe. It's really hard to diagnose without more information.
Jeff
Caleb94chevy
Reg: 12-17-17
12-18-17 08:52 AM - Post#2718340
    In response to rockfangd
Fuel spray pattern seems good when just checking with a flashlight no dripping that I’ve noticed. Timing is at 2 BTDC with timing advance wire disconnected. So not bad for a tbi shouldn’t hurt it to much. Runs at around 25 degrees at idle tho.
Caleb94chevy
Reg: 12-17-17
12-18-17 08:54 AM - Post#2718341
    In response to bowtie44s
To check that I just pull the valve covers off and watch the rockers lift right?
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
12-19-17 10:08 AM - Post#2718430
Yep, if you have a flat lobe, it will still move, but not nearly as much.
Jeff
Execution time: 0.273 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:22 AM
