Username Post: 292 blower        (Topic#348727)
Mick53
Platinum Supporting Member
Mick53
Loc: Northern Indiana
Reg: 04-02-16
12-16-17 02:30 PM - Post#2718158
Here is the blower setup I'm getting. Mine will have serpentine accessories and the blower belt will power the oil pump. I guess because I will have no distributer. Also the 3-2 bbl carbs.
Attachment: blower.jpg (12.29 KB) 30 View(s)
bobschevytrucks.com Ecklers Chevy Trucks
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
12-16-17 07:25 PM - Post#2718184
    In response to Mick53
Hi Mick, Belt driven oil pumps can be very expensive and if you lose the belt you can loose the engine.
I can see you may want to use crank trigger ignition but you can still drive the oil pump with a dummy distributor.
My Blower engine is the wrong type for this forum and has crank trigger ignition and a dummy driver for the oil pump. The blower snout goes right through where an ordinary distributor would go and I don't like using a crab cap and lifting the blower to work on the ignition.
Also my ignition module has a boost retard function as the PSI goes up.
Cheers Kiwi
Mick53
Mick53
Reg: 04-02-16
12-16-17 08:08 PM - Post#2718192
    In response to Bel Air kiwi
Thanks Kiwi. I'll leave that to them. Maybe an alarm and a spare belt. I don't know a lot about that stuff. I build factories. I'll mention it to them.
Execution time: 0.263 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:11 PM
