Username Post: 04 Silverado 2500HD - Bleeding brakes        (Topic#348682)
Keith Seymore
Keith Seymore
Loc: Southeast Michigan
Reg: 09-17-08
12-13-17 12:55 PM - Post#2717811
I'm going to be replacing the brake lines on my '04 2500HD.
Do I need to cycle the ABS in order to bleed them and, if so, how do I do that?
Thanks in advance -
K
(Edit- Ew! Post #666!)
Chevelle Intro: http://www.popularhotrodding.com/features/1005phr_...
My Pontiacs: http://forums.maxperformanceinc.com/forums/showthr...
Pickup: http://67-72chevytrucks.com/vboard/showthread.php?...
Edited by Keith Seymore on 12-13-17 12:56 PM. Reason for edit: No reason given.
12-13-17 07:41 PM - Post#2717859
    In response to Keith Seymore
Usually done with the appropriate scanner, I've some success removing the fuses and this causes the abs valves to "home", then the abs can be bled.
Keith Seymore
Keith Seymore
Reg: 09-17-08
12-14-17 11:25 AM - Post#2717903
Ok - thank you -
K
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
12-14-17 07:29 PM - Post#2717965
Or you can Google " gravel road bleeding " it works every time.
Keith Seymore
Keith Seymore
Reg: 09-17-08
01-02-18 08:59 AM - Post#2719770
    In response to junkman104
Just to close the loop here: I'm all set.
I bought the GM replacement "kit" (GM part #22932565 for a crew cab 6.5ft box) which consists five pre-bent lines - four for the front and one going to the rear.
Bleeding was no problem. I was able to gravity bleed to get started and then did a vacuum bleed. I've been driving it for a couple weeks now and will probably go back and do one more pressure bleed when it is convenient.
The pre bent lines were nice, for the front. For the rear there were some tight spots behind the fuel tank, crossing over the rail and under the rear wire harness bundle. I think it would have been easier for that to be a straight line and bend to suit under the truck.
Hardest part about the whole thing was getting the stuck brake bleeder screws out.
K
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
01-02-18 09:38 AM - Post#2719776
I had to get a new caliper for my Suburban. I got 3 bleeders loose and one twisted off.
Jeff
'88 Chevy K3500, aluminum head roller cam 511inĀ³ stroker 10.5:1 compression, 96 NV 4500, 94-98 grille, 305/70-16 (33x12) BF Goodrich KM2s, 91 cluster swap
Execution time: 0.35 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:08 AM
