Username Post: 1968 chevy truck over heating        (Topic#348675)
dave5287
Loc: ny
Reg: 04-12-13
12-13-17 05:22 AM - Post#2717765
my 350 chevy motor is over heating change heads and gasket still pushing water out radiator looked at heads they look good no cracks did not see any in cylinder walls either any ideas thank you dave
1967 chevy c20 1968 gmc c2500 1969 gmck2500 1972 chevy k20 1964 chevy impala
Andy4639
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
12-13-17 06:02 AM - Post#2717766
    In response to dave5287
When you say it's over heating how did you check it?
Do you have a over flow on it?
1956 Bel Air - LT-1/4l60
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
dave5287
Loc: ny
Reg: 04-12-13
12-13-17 06:12 AM - Post#2717768
    In response to Andy4639
had radiator cap off within a few seconds water just came goshing out
Andy4639
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
12-13-17 06:19 AM - Post#2717772
That's normal if the radiator was over full. On a factory radiator the water level is about 2-4"'s below the cap. There should be a mark on the radiator telling you where the water line is.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
dave5287
Loc: ny
Reg: 04-12-13
12-13-17 06:26 AM - Post#2717773
I cant hold my hand over the radiator fill to much pressure pushing my hand off is there something im missing by putting new heads and gaskets on I even changed the thermo stat
Edited by dave5287 on 12-13-17 06:27 AM. Reason for edit: No reason given.
Andy4639
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
12-13-17 11:21 AM - Post#2717802
Did you get all the air out of the system? I would jack the front of the truck up and make sure it's not got any air trapped in it.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
12-15-17 08:21 PM - Post#2718089
if you start it and its overheating that fast im thinkin you have a compression leak into the cooling system. you need to pressure test the cooling system to see if there is a leak into one of the cylinders.
Execution time: 0.285 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:42 AM
