Username Post: Wheel Torque        (Topic#348629)
AmericaMade
Reg: 11-06-17
12-10-17 12:57 PM - Post#2717495
1983 Chevy Scottsdale C10 whats is the proper torque for 1/2 inch lug nuts 5 stud pattern 31x10.5x15
Edited by AmericaMade on 12-10-17 12:59 PM. Reason for edit: No reason given.
LMC Truck
12-10-17 04:13 PM - Post#2717506
    In response to AmericaMade
Studs and lug nuts in good shape I'd say 120.
elcamino
elcamino
Reg: 03-30-00
12-10-17 05:05 PM - Post#2717508
From an 1981 Service manual, 75-100 ft lbs
2017 GMC Sierra Denali Ultimate 6.2L(420hp)/8-sp
2016 Polaris RZR 900 EPS
AmericaMade
Reg: 11-06-17
12-10-17 05:15 PM - Post#2717509
    In response to elcamino
Thank you. It’s surprising how this basic question has zero google return. I did 90. Thanks again
12-10-17 05:50 PM - Post#2717511
I'd say that is low for that size tire and weight.
Edited by Shepherd on 12-10-17 07:19 PM. Reason for edit: No reason given.
100 CHEVY
100 CHEVY
Loc: Helena,Missippi,U.S.A.
Reg: 12-09-04
12-10-17 08:45 PM - Post#2717531
The torque on my 1 ton trucks is 130.
So,a 1/2 ton will be somewhat less.
Although I've never torqued a 1/2 trucks lug nuts.
Mike.
elcamino
elcamino
Reg: 03-30-00
12-11-17 03:19 AM - Post#2717542
In comparison, the wheel torque on my 2017 Sierra Denali crew cab 4x4 with 22-inch aluminum wheels is 140 ft lbs.
Senior Chevytalk Moderator
12-11-17 06:18 AM - Post#2717551
Aluminum wheels are require a lot more torque. Steel less. I've snapped off a few steel lugs.
LMC Truck
Execution time: 0.263 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:47 AM
