Username Post: Front clip difference in 1970 & 1972        (Topic#348609)
HAVE 1970 GMC
Loc: Maple Valley, WA
Reg: 01-27-17
12-08-17 10:35 AM - Post#2717318
Is there much difference in the 1970 &1972 Front clip. I have a chance to pick one up but want to be sure before I dive 2 hours to look at it. The photos look close but what am i missing?
JimKshortstep4x4
Chevytalk Moderator & "14th Year" Silver Supporting Member
JimKshortstep4x4
Loc: Muskegon, MI, USA
12-08-17 04:15 PM - Post#2717341
    In response to HAVE 1970 GMC
Fenders and hood are basically the same. Grills look different since the turn signals are mounted in them but will interchange. I believe the 70 has the Bowtie emblem on the hood but of course this will not affect fit.
71, 72 have the turn signals in the bumpers.
66 Impala SS, 396, TH 400
69 El Camino, 350, TH 350
HAVE 1970 GMC
Reg: 01-27-17
12-08-17 06:06 PM - Post#2717351
Jim, I went on Paul's Parts and looked at grilles and the only difference I see is one has black paint as high lights.
JimKshortstep4x4
JimKshortstep4x4
12-10-17 08:21 AM - Post#2717482
You are right on the grills and they will interchange with no problems. You said GMC and I happened to answer for Chevy Grills, I apologize!
Andy4639
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
12-13-17 06:15 AM - Post#2717770
The front ends are basically the same with only cosmetic changes which don't effect fitment. Most clips will work even the earlier model ones will bolt up to the later models with only a radiator support change.
The only problem with a GMC grille is the double head lights.
As stated the turn signals will have to be moved to which ever one you choose.
1956 Bel Air - LT-1/4l60
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Edited by Andy4639 on 12-13-17 06:16 AM. Reason for edit: No reason given.
Execution time: 0.207 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:25 AM
