Username Post: Air Conditioner recharge        (Topic#348596)
Buddy Mewbourne
Loc: Talladega, Alabama
Reg: 03-04-04
12-07-17 05:08 PM - Post#2717224
I have an after market air conditioner set up in my 39. I need to recharge the system. The quick connect hose that I have won't fit the low pressure outlet on the compressor. Do they make different quick connect fittings? Never run to this problem before.
Second Bridge Garage
12-07-17 06:45 PM - Post#2717229
    In response to Buddy Mewbourne
Maybe it is the high side fitting? Which won't fit the low side. or you are using old style r12 fittings?
Buddy Mewbourne
Reg: 03-04-04
12-08-17 02:55 AM - Post#2717269
Thanks Shepard. I'll try that. Don't know if I'm trying to use an old R-12 fitting. I'll check.
Ray P W
Reg: 09-30-15
12-08-17 10:00 PM - Post#2717371
Buddy,
I have an R12 gauge set that I also use on our R134 cars. All it took to be able to do that was an inexpensive adapter set from O'Reilly Auto Parts.
Ray W
Execution time: 0.265 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:20 AM
